"Failed Connection Attempt"
"Failed Connection Attempt" - 17.Jul.2008 11:02:18 PM
sander99
I have some clients that do not specify a proxy server in the browser settings (all checkboxes are blank). These clients generate the "failed conenction attempt" error. As soon as I configure a proxy in the client's browser settings everything works. However, for the corporate laptop I would not like to change the browser setting. It seems that the reason for my issue that none of the rules seems to apply. Is there a solution? For some reason this setup used to work with the WinProxy product.
RE: "Failed Connection Attempt" - 19.Jul.2008 11:44:25 AM
Status: online
Remember that the ISA firewall is a firewall, so you need to configure the firewall to allow the connections you want through the firewall. What rules have you configured on the firewall to allow the outbound connections? Tom
RE: "Failed Connection Attempt" - 19.Jul.2008 12:08:08 PM
sander99
At this point I have a simple rule that allows all internal network traffic to go to the external network, through all ports, for all users (I'm not using authentication).
RE: "Failed Connection Attempt" - 20.Jul.2008 10:47:06 AM
sander99
Yes, the default gateway is the IP of the box with ISA. The DHCP server (on the smae box) has a gateway entry that gets distributed.
RE: "Failed Connection Attempt" - 21.Jul.2008 7:12:34 PM
sander99
I have a DNS (Windoes) server on the same box. To make things more complicated, one client works in the meantime again...
RE: "Failed Connection Attempt" - 22.Jul.2008 11:57:24 AM
sander99
Yes, that part is working. The browse seems even to find the the ISA sever proxy as it serves up an ISA generated web page. I suspect that an ISA rule doesn't trigger, doesn't recognize the client.
RE: "Failed Connection Attempt" - 23.Jul.2008 8:50:43 AM
Status: online
Check the firewall logs on the firewall and see what is happening to the connection attempts through the firewall when the clients can't get past the firewall. HTH, Tom
