:- Need Help - :
All Forums >> [ISA Server 2004 Firewall] >> Access Policies >> :- Need Help - : Page: [1]
:- Need Help - : - 18.Jul.2008 1:31:01 AM
daslaniya_mahendra
Dear All,
     How to open luce.sunymaritime.edu:2048/menu  site.  all sites is open good but except xyz.com:1023 or xyz.com:2048 not opening please help for which port to be add or which type of rule to be apply.
RE: :- Need Help - : - 18.Jul.2008 11:58:54 AM
Create a new protocol , example : TCP outbound 2048.
And include this protocol with your rule, if you are using the All Outbound protocols , then no need to add this rule in the rule, as its already included when you select All Outbound Protocols
Tarek
(in reply to daslaniya_mahendra)
RE: :- Need Help - : - 21.Jul.2008 4:52:46 AM
daslaniya_mahendra
Hello Sir,
Thx for reply,
       I had create rule as per your instuction but same error will appare.
TCP Outbond 2048  -  range 2048 to 2048. have other idea
(in reply to elmajdal)
