[SOLVED] Port stealing inconsistency?
[SOLVED] Port stealing inconsistency? - 13.Aug.2008 6:28:10 PM
Arcesilaus
Hi Here's the case that drives me crazy! I have an ISA 2006 configured as an edge firewall that resides behind a Netscreen firewall (to maintain IP-Sec policies), using two nics: 1 internal and 1 external. The Netscreen forwards the HTTP requests untranslated to the ISA server's external NIC. I've configured a NAT networking rule between all networks I've published multiple websites (using host headers) that all reside on the same server in the same subnet as the ISA's internal NIC, that has 1 IP. Here's the problem: - For some of them, the requests are identified as: source = any public IP, destination = published IP of the webserver
This one is working fine, as traffic is allowed. - For some others, the requests are identified as: source = any public IP, destination = external NIC of the ISA server
You guessed, this is not working: the Default rule denies traffic. It simply drives me crazy: the policy rules are absolutely identical! What is going on here? It seems to me it is a fairly simple setup, isn't it? The webserver does not (yet) have the ISA server as its gateway and the ISA server forwards the requests as if they were originated by the ISA server. To make it even worse: - Simulating traffic from any public IP to both websites shows access is denied! How can it be that the actual requests, exactly similar to the one simulated, is allowed for some of the websites?
Apparently, the traffic simulator sees the ISA's external NIC as the destination IP, similar to those cases were actual traffic is denied. For some reason, requests to some of the websites are 'stolen' from the ISA's external IP and translated into the published server IP. Why is this not the case for all websites?
< Message edited by Arcesilaus -- 13.Aug.2008 8:57:16 PM >
Homo sum: humani nil a me alienum puto (Terence)
