[noob] Front firewall with Sonic behind - routing help
[noob] Front firewall with Sonic behind - routing help - 27.Oct.2008 12:57:44 PM
ipgisa
Hi, I am setting up an ISA2006 as the front firewall with a Sonic hardware firewall behind it. I can't use ISA as a back firewall because the Sonic has dual ISP connections and I can only have one gateway. I've configured my ISA external NIC with a valid static IP and gateway (no DNS) and the perimeter NIC with a private IP, no gateway and DNS. The perimeter NIC is in the perimeter network so a different network from my internal DNS servers on the LAN. What, if any, static routes do I need to add to make sure I can publish the external IP of the SONIC that has NAT'd servers behind it? Or is this completely backwards? Thanks SONIC external 192.168.42.2 ISA perimeter 192.168.42.1 ISA external x.z.y.1 Perimeter network 192.168.42.* LAN 192.168.43.* INTERNET1 INTERNET2 || || ISA || || || SONIC======== || LAN
RE: [noob] Front firewall with Sonic behind - routing help - 29.Oct.2008 8:09:25 AM
Put the Sonic Wall in front of the ISA firewall. Then configure the ISA firewall to use the LAN interface of the Sonicwall as its default gateway. HTH, Tom
RE: [noob] Front firewall with Sonic behind - routing help - 29.Oct.2008 2:19:28 PM
ipgisa
Hi, Actually I would very much like to do that, but I have a site-site VPN between the Sonic and another Sonic on the INTERNET2 connection. I do not know if I can connect the remote Sonic VPN through the local Sonic VPN to the ISA server which is what would have to happen. The Sonics do not support PPTP so it would have to be IPsec pass through of some sort. Thanks
RE: [noob] Front firewall with Sonic behind - routing help - 4.Nov.2008 7:28:37 AM
You can still terminate the site to site VPN on the sonicwall in front of the ISA firewall. I did an article about a year ago on how to do this. HTH, Tom
