0x80074e20 FWX_E_GRACEFUL_SHUTDOWN
All Forums >> [ISA Server 2004 Firewall] >> General >> 0x80074e20 FWX_E_GRACEFUL_SHUTDOWN Page: [1]
0x80074e20 FWX_E_GRACEFUL_SHUTDOWN - 9.Nov.2006 4:33:21 AM
johnnyya
Hello All,
I have a problem with access to different services in the Internet.
A day ago users in the LAN lost possibility to send emails.
Analizing ISA 2004 logs I have noticed the errors like provided below:
Original Client IP Client Agent Authenticated Client Service Referring Server Destination Host Name Transport HTTP Method MIME Type Object Source Source Proxy Destination Proxy Bidirectional Client Host Name Filter Information Network Interface Raw IP Header Raw Payload GMT Log Time Source Port Processing Time Bytes Sent Bytes Received Cache Information Error Information Log Time Client IP Destination IP Destination Port Protocol Action Rule Result Code HTTP Status Code Client Username Source Network Destination Network URL Server Name Log Record Type
000.000.000.252 - TCP - - - 09.11.2006 9:11:43 56588 0 0 0 0x0 0x0 09.11.2006 12:11:43 000.000.000.252 194.67.23.111 25 SMTP Initiated Connection Unrestricted Internet access 0x0 Local Host External - GATE Firewall
000.000.000.252 - TCP - - - 09.11.2006 9:11:57 56451 69719 144 0 0x0 0x0 09.11.2006 12:11:57 000.000.000.252 194.67.23.111 25 SMTP Closed Connection Unrestricted Internet access 0x80074e20 FWX_E_GRACEFUL_SHUTDOWN Local Host External - GATE Firewall
11.50.0.31 brwconf.exe:3:5.1 - TCP - - - 09.11.2006 9:12:02 1648 0 0 0 0x0 0x0 09.11.2006 12:12:02 11.50.0.31 67.28.113.73 25 SMTP Initiated Connection Unrestricted Internet access 0x0 SYSTEM (?) Internal External - GATE Firewall
11.50.0.31 brwconf.exe:3:5.1 - TCP - - - 09.11.2006 9:12:07 1650 0 0 0 0x0 0x0 09.11.2006 12:12:07 11.50.0.31 67.28.113.19 25 SMTP Initiated Connection Unrestricted Internet access 0x0 SYSTEM (?) Internal External - GATE Firewall
11.50.0.31 brwconf.exe:3:5.1 - TCP - - - 09.11.2006 9:12:12 1651 0 0 0 0x0 0x0 09.11.2006 12:12:12 11.50.0.31 4.79.181.14 25 SMTP Initiated Connection Unrestricted Internet access 0x0 SYSTEM (?) Internal External - GATE Firewall
11.50.0.31 brwconf.exe:3:5.1 - TCP - - - 09.11.2006 9:12:17 1652 0 0 0 0x0 0x0 09.11.2006 12:12:17 11.50.0.31 4.79.181.15 25 SMTP Initiated Connection Unrestricted Internet access 0x0 SYSTEM (?) Internal External - GATE Firewall
11.50.0.31 brwconf.exe:3:5.1 - TCP - - - 09.11.2006 9:12:22 1653 0 0 0 0x0 0x0 09.11.2006 12:12:22 11.50.0.31 4.79.181.168 25 SMTP Initiated Connection Unrestricted Internet access 0x0 SYSTEM (?) Internal External - GATE Firewall
000.000.000.252 - TCP - - - 09.11.2006 9:12:52 56588 69188 144 0 0x0 0x0 09.11.2006 12:12:52 000.000.000.252 194.67.23.111 25 SMTP Closed Connection Unrestricted Internet access 0x80074e20 FWX_E_GRACEFUL_SHUTDOWN Local Host External - GATE Firewall
11.50.0.31 brwconf.exe:3:5.1 - TCP - - - 09.11.2006 9:13:05 1648 63328 96 0 0x0 0x0 09.11.2006 12:13:05 11.50.0.31 67.28.113.73 25 SMTP Closed Connection Unrestricted Internet access 0x80074e20 FWX_E_GRACEFUL_SHUTDOWN SYSTEM (?) Internal External - GATE Firewall
11.50.0.31 brwconf.exe:3:5.1 - TCP - - - 09.11.2006 9:13:10 1650 63344 96 0 0x0 0x0 09.11.2006 12:13:10 11.50.0.31 67.28.113.19 25 SMTP Closed Connection Unrestricted Internet access 0x80074e20 FWX_E_GRACEFUL_SHUTDOWN SYSTEM (?) Internal External - GATE Firewall
11.50.0.31 brwconf.exe:3:5.1 - TCP - - - 09.11.2006 9:13:15 1651 63344 96 0 0x0 0x0 09.11.2006 12:13:15 11.50.0.31 4.79.181.14 25 SMTP Closed Connection Unrestricted Internet access 0x80074e20 FWX_E_GRACEFUL_SHUTDOWN SYSTEM (?) Internal External - GATE Firewall
11.50.0.31 brwconf.exe:3:5.1 - TCP - - - 09.11.2006 9:13:20 1652 63344 96 0 0x0 0x0 09.11.2006 12:13:20 11.50.0.31 4.79.181.15 25 SMTP Closed Connection Unrestricted Internet access 0x80074e20 FWX_E_GRACEFUL_SHUTDOWN SYSTEM (?) Internal External - GATE Firewall
Searching for solution in some forums hasn't brought any results.
Also I haven't found the messages in the Windows Events.
The system consists of Windows 2003 Server + ISA 2004.
Please HELP!!!
RE: 0x80074e20 FWX_E_GRACEFUL_SHUTDOWN - 16.Nov.2006 10:55:41 AM
What device is sending the outbound SMTP messages?
(in reply to johnnyya)
RE: 0x80074e20 FWX_E_GRACEFUL_SHUTDOWN - 20.Nov.2006 2:31:14 AM
johnnyya
I've found all causes of the problem.
Actually, it was not a problem, SMTP outbound traffic from the local network had been blocked by ISProvider, because a computer in the local network had got a troyan, which was sending junk messages. Domestic system administrator missed this event, so the problem have occured.
Thank you, Tom, for your attention.
Johnny.
RE: 0x80074e20 FWX_E_GRACEFUL_SHUTDOWN - 4.Dec.2006 11:14:43 AM
Hi Johnny,
Great! Good to hear you got things working and thanks for the follow up!
