0x80074e24 FWX_E_CONNECTION_KILLED error when conencting VPN
All Forums >> [ISA Server 2004 Firewall] >> VPN >> 0x80074e24 FWX_E_CONNECTION_KILLED error when conencting VPN Page: [1]
0x80074e24 FWX_E_CONNECTION_KILLED error when conenctin... - 11.Apr.2005 6:37:00 PM
Marsdy
I have a fairly standard ISA 2004 set up with a number of remote sites all configured with the same options for sit-to-site VPN.
Some of the site-to-site VPNs connect fine and others dont (they all connected fine using ISA 2000)
Looking at the logs, it appears that ISA 2004 is killing the connection once it is established but I can't tell why.
I have tried turning off intrusion detetcion, IP option checking in case that was the cause but to no avail.
Logs from a typical exchange are given below (with real IP addresses replaced where necessary) showing the error - any ideas what else I can try?
TCP 84.9.XX.XXX:1429 213.86.YY.YYY:1723 Local Host External Establish 0x0 Allow VPN site-to-site traffic from ISA Server PPTP
GRE 84.9.XX.XXX 213.86.YY.YYY Local Host External Establish 0x0 Allow VPN site-to-site traffic from ISA Server PPTP
TCP 84.9.XX.XXX:1429 213.86.YY.YYY:1723 Local Host External Terminate 0x80074e24 Allow VPN site-to-site traffic from ISA Server PPTP
RE: 0x80074e24 FWX_E_CONNECTION_KILLED error when conen... - 13.Apr.2005 12:53:00 PM
Hi Marsdy,
Are your rules configured correctly to support the site to site VPN connection?
(in reply to Marsdy)
RE: 0x80074e24 FWX_E_CONNECTION_KILLED error when conen... - 14.Apr.2005 3:33:00 PM
Marsdy
Yes, I have a number of sit-to-site VPNs configured and most work and a couple dont. There is no difference between the configuration of the ones that do and dont work other than the server, name and password
RE: 0x80074e24 FWX_E_CONNECTION_KILLED error when conen... - 14.Apr.2005 3:56:00 PM
remdotc
Compair the values of
hkey_local_machine\currentcontrolset\services\tcpip\peremters
of the working VPN site to sites and the ones that do not. (assuming they are windows boxes)
RE: 0x80074e24 FWX_E_CONNECTION_KILLED error when conen... - 14.Apr.2005 5:59:00 PM
Marsdy
Under that key there is an "Interfaces" key and then various GUIDS but none of them appear to have any way of mapping to the RRAS entries for the VPNs
RE: 0x80074e24 FWX_E_CONNECTION_KILLED error when conen... - 14.Apr.2005 9:42:00 PM
remdotc
Actually you need to look at the values, Namely DWORD values, not the GUIDs, as the GUIDS map to virtual pointers that later map back to your NIC(s)
UseDomainNameDevolution
ForwardBroadcasts
EnableSecurityFilters
EnablePMTUDiscovery
EnableICMPRedirect
IPAutoconfigurationEnabled
NoNameReleaseOnDemand
If you are using ADS, you should also check out
string value
Domain
