10060 A connection attempt failed because the connected party did not properly respond after...
10060 A connection attempt failed because the connected... - 12.Apr.2008 8:10:10 PM
sybrix69
Hi Guys, I need some help with ISA 2004 + Publishing OWA. I have a follow all the document from ISAServer.org and other articles on the web. Here is the scenario Network diagram: [ DMZ] Internet <---> CISCO PIX <---> NIC-2<----> ISA2004<---->NIC1<--->LAN 10.32.4.1 10.32.6.50 10.32.4.10 10.32.6.1 Network Interface setup: NIC 1 - LAN : 10.32.4.10, sub: 255.255.255.0, DNS: 10.32.4.9 Append parent suffixes of the primary DNS suffix register this connection address in DNS Enable Netbios over TCP/IP Client for Microsoft networks, and files and printer sharing for MS network NIC 2 - WAN: 10.32.6.50, sub: 255.255.255.0, GW:10.32.6.1 Disable: Client for Microsoft networks, and files and printer sharing for MS network Append parent suffixes of the primary DNS suffix Disable: Enable Netbios over TCP/IP Adapter and Binding: 1. LAN --- 2. WAN --- 3.Remote access connections Template: Backend network template Publishing Mail server (template) From: Anywhere To: OWA.****.com.au, foward the orginal host header instead of the actual one Request appear to come from the ISA Server computer Listener: OWA SSL Listener; network: External (10.32.6.50), Enable SSL: 443, certificate: OWA.****.com.au, Authentication: OW Form-Based, Domain Name athentication: ****.local Users: All Users Bridging: Web server; Redirect request to SSL port: 443 Public Name: OWA.****.com.au In IIS on Exchange 2003 server, I have follow the M$ doco to change from Integrate authentication to basic authentication under Exchange/exchweb and annoymous authentication for /pub. We purchase a SSL certificate, not using the Windows Certificate Currently the only Firewall Policy is OWA WEB ACCESS and Default rule by the (system policy) What been tested: Inside of the LAN network, we able to use https://****/exchange, a SSL message display "saying not safe and etc..." hit continues and able to login to OWA Add a host file on a PC system which is on the same segment on the DMZ where the NIC2 (10.32.6.50) of ISA2004 connected. Host file contain 10.32.6.50 map to owa.****.com.au. Using Internet explorer with no proxy server. Was able ping and connected to https://owa.****.com.au; enter user name and password, and was directed to the inbox. Problem here is that I was not able to select any folder in OWA eg:- inbox, outbox and etc... no contents email showing Look at the ISA monitoring log, the follow error message been captured:- ----------------------------------------------------------------------------------- Failed Connection Attempt EPISA01 11/04/2008 12:16:08 PM Log type: Web Proxy (Reverse) Status: 10060 A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. Rule: OWA WEB ACCESS Source: External ( 10.32.6.40:0) Destination: (owa.****.com.au 10.32.4.11:443) Request: GET https://owa.****.com.au:443/exchange/ Filter information: Req ID: 07208dc7 Protocol: https User: anonymous Client agent: Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.2; SV1; .NET CLR 1.1.4322)Object source: Internet Processing time: 21219Cache info: 0x0 MIME type----------------------------------------------------------------------------------- Failed Connection Attempt EPISA01 13/04/2008 8:46:14 AM Log type: Web Proxy (Reverse) Status: 12210 An Internet Server API (ISAPI) filter has finished handling the request. Contact your system administrator. Rule: Source: ( 10.32.6.40:0) Destination: ( 10.32.6.50:443) Request: GET http://owa.****.com.au/CookieAuth.dll?GetLogon?url=%2Fexchange&reason=0 Filter information: Req ID: 07208ed4 Protocol: https User: anonymous Client agent: Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.2; SV1; .NET CLR 1.1.4322)Object source: Processing time: 203Cache info: 0x0 MIME type: ----------------------------------------------------------------------------------- Could anyone see any problem with the setup or have I miss any steps? Please help or have any suggestion it's would be great !!!!
< Message edited by sybrix69 -- 12.Apr.2008 8:14:04 PM >
