12206 - proxy chain loop
All Forums >> [ISA Server 2000 General] >> Web Publishing >> 12206 - proxy chain loop Page: [1]
12206 - proxy chain loop - 24.Apr.2002 7:18:00 PM
williamolson
I usedto have OWA working. I have made some DNS changes. Now I get a chaining error. I have this article: http://support.microsoft.com/directory/article.asp?ID=KB;EN-US;Q269165&
Are there any other areas I should look to correct this?
TIA - William
RE: 12206 - proxy chain loop - 25.Apr.2002 6:37:00 PM
Hi William,
What type of error are you getting?
How did the DNS changes influence the problems you're having with OWA?
(in reply to williamolson)
RE: 12206 - proxy chain loop - 26.Apr.2002 3:39:00 PM
williamolson
proxy chaining loop 122206 is the error Tom.
We were unable to see our web site internally; we changed some DNS settings and things inside and outside and things work fine except for OWA.
RE: 12206 - proxy chain loop - 26.Apr.2002 7:26:00 PM
Abraham
William try to test this, make a ping from any computer in your lan, to the Company Web site URL, then, if you see any response from the IP address of the external NIC,try to change so you can have response fron the internal NIC.May be
editing HOSTS files, or in you DNS. then check you Web Publishing Rules for OWA, and Restart ISA Services.
RE: 12206 - proxy chain loop - 29.Apr.2002 9:06:00 PM
williamolson
Abraham,
As it turns out, I only needed to re-order the cards so that the internal NIC was 1st and the externa-2nd.
Thanks for your suggestion.
Problem solved.
William
