13301 Connection to FTP site
All Forums >> [ISA Server 2000 Firewall] >> Firewall Client >> 13301 Connection to FTP site Page: [1]
13301 Connection to FTP site - 18.Apr.2006 6:11:00 PM
MLT
I am having problems accessing a particular FTP site.  I am using the Firewall client.  I have no problems accessing sites with the following address type:
ftp.sitename.com
However when I try to access an FTP site at the following
www.sitename.com
It does not work.  I get a 13301 in the firewall log.  I am attempting to access the site just using the DOS command.
If I go to IE and type ftp://username:pwd@www.sitename.com I get read only access which is what I expect.  However, I need to have write access to this site.
I have the FTP application filter enabled, the protocol definitions for FTP and FTP Server, a protocol rule including the definitions for any request.
What am I missing?  It appears in my firewall log that sucessfull connections use two rules - Internet Access and Allowed Web Sites.  On my failed connection it does not use any rules.
If I change my user to be "unrestricted" which uses a rule called Allow Rule, everything works perfect.  As soon as I switch back to the Allowed Web Sites rule is when things don't work.  I have *.sitename.com in my Destination set for that rule but still no dice.
Any help is greatly appreciated!
< Message edited by MLT -- 18.Apr.2006 6:18:33 PM >
The actual error is 13301 - Sorry about the typo - 18.Apr.2006 6:12:41 PM
MLT
(in reply to MLT)
RE: 13301 Connection to FTP site - 18.Apr.2006 8:41:35 PM
Hi MLT,
for the meaning of '13301' check out http://support.microsoft.com/default.aspx?scid=kb;en-us;284818. So, your firewall policy doesn't allow that type of traffic. What is the content of the log fields Rule#1 (protocol rule) and Rule#2 (site&content rule) for that traffic?
(in reply to MLT)
RE: 13301 Connection to FTP site - 18.Apr.2006 9:48:51 PM
MLT
Steffan here are the entries in the log:
192.168.1.75 dobrien ftp.exe:3:5.1 2006-04-18 13:30:34 OCCSRV www.opechee.com 209.41.170.70 - - - - - - GHBN 0 - Allowed Web Sites 69 0
192.168.1.75 dobrien ftp.exe:3:5.1 2006-04-18 13:30:34 OCCSRV - 209.41.170.70 21 - - - 21 TCP Connect 13301 - - 69 110
Notice the first entry with one rule and the second entry does not contain any.  A successfull ftp connection does this:
192.168.1.75 dobrien ftp.exe:3:5.1 2006-04-18 13:30:46 OCCSRV ftp.greatbaycommons.com 68.142.234.89 - - - - - - GHBN 0 - Allowed Web Sites 69 0
192.168.1.75 dobrien ftp.exe:3:5.1 2006-04-18 13:30:46 OCCSRV - 68.142.234.89 21 15 - - 21 TCP Connect 0 Internet Access Allowed Web Sites 69 111
192.168.1.75 dobrien ftp.exe:3:5.1 2006-04-18 13:31:09 OCCSRV - 68.142.234.89 21 22390 13 244 21 TCP Connect 20000 Internet Access Allowed Web Sites 69 111
I knew what the error meant, I'm just having a tough time trying to figure out where I went wrong.  Its really odd.
(in reply to spouseele)
RE: 13301 Connection to FTP site - 18.Apr.2006 10:08:49 PM
Hi MLT,
aha... it seems that there is no match for a site&content rule. So, I guess that a forward and reverse DNS lookup doesn't match for those failing sites with an entry in your 'Allowed Web Sites'.
For more info, check out my article http://www.isaserver.org/tutorials/The_Mystery_of_the_HTTP_Redirector_and_SiteContent_Rules.html, particular section '3. Site&Content Rules'.
(in reply to MLT)
RE: 13301 Connection to FTP site - 18.Apr.2006 10:29:17 PM
MLT
Stefaan you are the man!!!!
I had some bizarre reverse DNS entries.  Added them to my Allowed Web Sites and BAM everything works.
Kudos to you!
RE: 13301 Connection to FTP site - 19.Apr.2006 8:35:53 PM
Hi MLT,
glad to hear I could help and thanks for the follow up!
(in reply to MLT)
