192.168.x.x load balnced on external interface.
All Forums >> [ISA 2006 General] >> General >> 192.168.x.x load balnced on external interface. Page: [1]
192.168.x.x load balnced on external interface. - 3.Nov.2006 10:07:59 AM
Digitus
Hi
I have an issue with loadbalncing on the external interface of my ISA array.
Environment:
ISA 2006 Enterprise Edition with on configuration server and one (a second to be added later) ISA server in the array. The ISA server have 3 NIC's in it connected as follows.
Internal (LAN): 172.190.x.x subnet
External (DMZ): 192.168.250.x subnet
Intra-Array: 192.168.100.x subnet
In additon there is a hadware firewall outside the 192.168.250.x subnet that provides NATing to the internet.
The internal interface (172.190.x.x subnet) has network loadbalancing enbled and is working the way it should. However when I try to enable netwook load balancing on the External (DMZ interface, 192.168.250.x) I get an error (See below) in the event log and network load balancing status changes changes to stopped.
Event log entry:
Event Type: Error
Event Source: Microsoft Firewall
Event Category: None
Event ID: 21113
Date:  03/11/2006
Time:  11:18:00
User:  N/A
Computer: ISA1
Description:
There is no suitable network adapter related to network 'External'. Network Load Balancing cannot be configured properly, and will be stopped on this server. A suitable network adapter must have a static IP address that belongs to the network and is different than the cluster Virtual IP address.
At this stage no traffic will flow through the external interface, and there are alerts in ISA complaining that there is no route through the adapter and that I should add it to the Array network. However I can't add it to the External Network as there is no option for that. I've tested it in a lab using different ranges and that works. Is there a limitation on using 192.168.x.x on the external interface and load balancing it? Any other suggestions as to what I can try?
Best regards,
Digitus
RE: 192.168.x.x load balnced on external interface. - 4.Nov.2006 11:34:32 AM
Hi Digitus,
Nope, no problem with 192.x.x.x networks.
You've got a typo or some other problem that is creating this issue.
(in reply to Digitus)
