2004 FWC with XP SP 2 (RTM)
2004 FWC with XP SP 2 (RTM) - 8.Aug.2004 8:09:00 PM
FORsaken
HI All
i just had a very odd problem .
ive install a fresh computer with WINXP SP2 RTM ( i got my copy today from MS ) , and after i have installed all the application on the computer to make an IMAGE from it ,i have installed ISA 2004 FWC , just after the installation of FWC the computer lost contact to the Network and the RCP of WINXP crashed ! , i tired to repair the machine but nothing worked! , so i tried to install it on another machine with diffrent hardware from scratch again , and BANG! the same problem , the machine RPC is crashing all the time and restarting the computer ( not to talk about the LONG LONG time untill WINXP boots again) ! i guess that somthing with WINXP SP2 (Final) and ISA 2004 FWC just dont work toghther ?????!
is this an undocument bug ??? or just a feature ??!
any help or a tip about that issue ????!
thanks ahead !
BTW: this is more then just an annoying problem , i want to update my network soon to WINXP SP2 , and i already use ISA 2004 RTM, so i will just keep using ISA 2000 FWC that makes no problem with WINXP SP2 .......... [ August 08, 2004, 08:14 PM: Message edited by: FORsaken ]
RE: 2004 FWC with XP SP 2 (RTM) - 9.Aug.2004 2:21:00 AM
Hi For,
Where did you get the release SP2? Can't tell you much until I see it.
RE: 2004 FWC with XP SP 2 (RTM) - 9.Aug.2004 7:38:00 AM
cbarneaud
XP SP2 RTM is available om MSDN.
RE: 2004 FWC with XP SP 2 (RTM) - 9.Aug.2004 8:34:00 AM
FORsaken
Thats Right tom ....... i got it from my MSDN ...
RE: 2004 FWC with XP SP 2 (RTM) - 9.Aug.2004 3:35:00 PM
Hey guys,
I have downloaded the SP2 from MSDN.
I'll give it a try now.
I'll report back after the test.
Thanks! Tom
RE: 2004 FWC with XP SP 2 (RTM) - 11.Aug.2004 5:37:00 AM
ClintD
Interesting - I've got WinXP SP2 installed as well as the ISA 2004 Firewall Client on my machine at work and I haven't run into problems.
Let me get a fresh install of WinXP with SP2 and the FWC and see what's what.
RE: 2004 FWC with XP SP 2 (RTM) - 11.Aug.2004 1:13:00 PM
Hi Client,
Just tested today. No obvious problems. However, Jim H mentioned that there are a couple of minor issues that have been reported to them and that a KB should be up soon.
RE: 2004 FWC with XP SP 2 (RTM) - 11.Aug.2004 8:12:00 PM
FORsaken
will you post a link to that KB when it will be published tom ??
RE: 2004 FWC with XP SP 2 (RTM) - 12.Aug.2004 5:28:00 PM
Hi 4,
You bet! I look for it everyday.
Thanks! Tom
RE: 2004 FWC with XP SP 2 (RTM) - 12.Aug.2004 11:55:00 PM
StarChase
Hi all,
Just for the info. I just reinastalled my whole computer, then SP2 and drivers, then firewall client. Now i dont have any problems @ all.
Greetz
RE: 2004 FWC with XP SP 2 (RTM) - 17.Aug.2004 12:32:00 AM
Hi Star,
