2006 Wishlist
All Forums >> [ISA 2006 Misc.] >> ISA 2006 Wish List >> 2006 Wishlist Page: [1]
2006 Wishlist - 19.Sep.2006 1:23:43 PM
fiftybuck$
I would like to see ISA allow an admin to do proper port forwarding and protocol routing.
Regards
Lionel
RE: 2006 Wishlist - 19.Sep.2006 1:31:00 PM
fiftybuck$
Sorry I posted this in the wrong place can an admin please move this post to ISA 2006 >> Misc >> ISA 2006 wishlist
(in reply to fiftybuck$)
RE: 2006 Wishlist - 19.Sep.2006 2:04:51 PM
alans
It doesn't are you using ISA 2006?
you sure you using ISA 2006 and not proxy 2.0
RE: 2006 Wishlist - 20.Sep.2006 4:59:40 AM
Hi Lionel,
Its does. What makes you think it doesn't?
(in reply to alans)
RE: 2006 Wishlist - 20.Sep.2006 3:08:05 PM
fiftybuck$
Hi Tom, I suppose I should have qualified my statement further:
It does do port forwarding through the publishing rules but you are limited as to which ports you can publish, obviously Microsoft have decided to lock down certain protocols as added security but an Admin should have the freedom to chose whichever port he wants to publish, this all came about as I am unable to publish port 389 (LDAP) for external access and it is highly frustrating, maybe I am wrong in this but would appreciate it if you could clarify it for me if I am.
Lionel
RE: 2006 Wishlist - 20.Sep.2006 5:49:21 PM
alans
Yes ISA comes with predifend ports but you can create your own definitions. Are you using the non-web server publishing wizard? If so in the wizard you can create new definitions and how it should handle the requests. Like listen on port 389 but forward to 386 if you want.
Have you read toms' book it gives a good understanding and a must to have.
Regards
AlanS
RE: 2006 Wishlist - 21.Sep.2006 2:35:52 PM
ORIGINAL: fiftybuck$
Lionel
Hi Lional,
You can publish TCP or UDP 389 if you like. You can use the built in LDAP protocols or create your own if you don't want someone else doing the work for you
You can create your own protocols, and then you can even tweak the source and destination ports after that  --- there's a ton of flexibilty in the ISA Firewall!
