2 external IP's on same NIC not working
2 external IP's on same NIC not working - 17.May2001 5:19:00 PM
mjmurphy2000
I have 2 external IP addresses installed on one network card. The problem I'm having is that when I configure each of the (2) websites I'm hosting in IIS w/ one of each of theses IP's, the only site that can be accessed is the site that uses the first IP in the network cards list. Any ideas?
RE: 2 external IP's on same NIC not working - 17.May2001 6:18:00 PM
mmillar
I've had similar problems on a couple of occasions. 1. Make sure you have installed both IP addresses BEFORE you install RRAS or ISA (it is either or both of them causing the problem but I didn't have time to work out which). Run IPCONFIG to see if both of your IP addresses have been assigned. The symptom of my problem was that one of the IP addresses kept saying 0.0.0.0. 2. I also had a 'funny'. Remove the second IP address from the listener, though leave it as 'Configure listeners individually per IP address'. Reboot. Then add the second address. Reboot. It worked for me! Martin
RE: 2 external IP's on same NIC not working - 17.May2001 6:31:00 PM
mjmurphy2000
After doing an IPCONFIG I do in fact see each IP listed under the external card. I don't however know what you mean when you say 'Configure listeners individually per IP address' Is this in ISA? I'm willing to try this if you can point me in the right direction as to where to find this setting. Thanks ! quote: Originally posted by mmillar: I've had similar problems on a couple of occasions.1. Make sure you have installed both IP addresses BEFORE you install RRAS or ISA (it is either or both of them causing the problem but I didn't have time to work out which). Run IPCONFIG to see if both of your IP addresses have been assigned. The symptom of my problem was that one of the IP addresses kept saying 0.0.0.0. 2. I also had a 'funny'. Remove the second IP address from the listener, though leave it as 'Configure listeners individually per IP address'. Reboot. Then add the second address. Reboot. It worked for me! Martin
RE: 2 external IP's on same NIC not working - 17.May2001 6:38:00 PM
mmillar
Run the ISA Management program. Right click on your server name - choose properties. Choose the 'Incoming Web Requests' tab. Select the 'Configure listeners individually per IP Address'. 'Add...' your second IP address. Easy. You know you don't need one IP address per website. If you use host headers you can have as many websites on one IP address as you want. Martin
