2 internal networks problem
All Forums >> [ISA 2006 Firewall] >> Network Infrastructure >> 2 internal networks problem Page: [1]
2 internal networks problem - 17.Jan.2007 3:42:30 AM
wanderer
Please if anybody could help me a little. My original configuration was 2 nics - one external and one internal network 192.168.1/24. The isa configured as edge firewall. everything worked fine. Now i want to add third nic for second internal network 192.168.2/24 so i can route between tho internal networks and apply some filtering of traffic between them. ISA ip for internal networks are: 192.168.1.2 for first internal and 192.168.2.2 for second. i created second internal network on isa and network rule to route between first and second. everything works fine but i wonder how ho allow internet acceess from users on second internal network 192.168.2/24? i tried and can't figure out. can i use same proxy as for first network (192.168.1.2) or should i enable web listener on the second network (192.168.2.2) and add second internal network in the network rule allowing nat access to external network and use ip 192.168.2.2 as proxy in browser?
RE: 2 internal networks problem - 17.Jan.2007 9:42:01 AM
wanderer
it works if i configure web listener on second (192.168.2) network and use 192.168.2.2 as proxy address in IE for client from that network, but this way is it possible to use autodiscovery? i setup users from network 192.168.2 to use dns server 192.168.1.1, it works fine, and wpad entry configured in dns points to 192.168.1.2. this way web access doesn't work. so the question is  if it possible to somehow make work 192.168.1.2 as proxy for clients from 192.168.2 or how to configure another wpad for users from 192.168.2 that would point to 192.168.2.2?
Please, some advice is really appreciated
(in reply to wanderer)
RE: 2 internal networks problem - 17.Jan.2007 2:14:40 PM
Hi wanderer,
check out Multi-Networking WPAD Support in ISA 2004.
RE: 2 internal networks problem - 18.Jan.2007 2:47:10 AM
wanderer
amazing. thank you
(in reply to spouseele)
RE: 2 internal networks problem - 18.Jan.2007 1:50:34 PM
Hi wanderer,
thanks!
