3-Leg Configuration problems - Help
3-Leg Configuration problems - Help - 1.Oct.2008 1:23:55 PM
pdsavard
HI, I try to configure correctly my 3-leg ISA server first the network: Nic1: Internal (10.0.1.51) No Default Gateway, Internal DNS Nic2: External (66.X.X.X) DG: ISP gateway NO DNS Nic3: Perimeter (10.0.5.1) No Default Gateway no dns (for now) After switching to 3-leg template I change the Perimeter->External to NAT et and the Perimeter->Internal to Route. I the Network tab of ISA I check that Internal see 10.0.1.0 to 10.0.1.255 and Perimeter see 10.0.5.0 to 10.0.5.255. I add this range in the PING system policy for testing purpose. I add this 2 testing access rule: - Allow, PING from Internal, to Perimeter, All user (name of the rule: Test2) - Allow, PING from Perimeter, to Internal, All user (name of the rule: Test) Not Ping result from a computer IN the perimeter network: - Ping the Perimter nic (10.0.5.1) : Ping OK - Ping the Internal nic (10.0.1.51): Ping OK - Ping another computer on the Internal network: Can't Ping Same result of ping from a computer inside the Internal Network. I can ping all the ISA nic but not a host in the other network. I monitor the ISA log when I do a PING: Original Client IP: 10.0.1.45 Transport: ICMP Client IP: 10.0.1.45 Destination IP: 10.0.5.44 Protocol:PING Action: Initiated Connection Rule: test2 Result Code: 0x0 ERROR_SUCCESS Source Network: Internal Destination Network: Perimeter Log Record Type: Firewall I forgot to mention that the Perimeter and Internal NIC have subnet mask set to 255.255.255.0, maybe is the point? The ISA server is a virtual machine in ESX 3.5, they use 3 virtual nic et 3 virtual switch. Any suggestion? Thanks EDIT: it is normal that in the ISA installation wizard I see all this route ? Its a brand new installation with only 2 nic card for now LAN NIC CARD Name: VMware Accelerated AMD PCNet Adapter IP Addresses: 10.0.1.51 Route Information: 10.0.1.0 - 10.0.1.255 , 10.255.255.255 - 10.255.255.255 WAN NIC CARD Name: VMware Accelerated AMD PCNet Adapter #2 IP Addresses: 66.158.135.134 Route Information: 0.0.0.1 - 10.0.0.255 , 10.0.2.0 - 10.255.255.254 11.0.0.0 - 126.255.255.255 , 128.0.0.0 - 223.255.255.255 240.0.0.0 - 255.255.255.254
< Message edited by pdsavard -- 2.Oct.2008 3:25:32 PM >
RE: 3-Leg Configuration problems - Help - 2.Oct.2008 3:25:13 PM
pdsavard
Here a copy of my routing table IPv4 Route Table =========================================================================== Interface List 0x1 ........................... MS TCP Loopback interface 0x10003 ...00 50 56 a1 7d 24 ...... VMware Accelerated AMD PCNet Adapter 0x10004 ...00 50 56 a1 19 e8 ...... VMware Accelerated AMD PCNet Adapter #2 0x10005 ...00 50 56 a1 30 15 ...... VMware Accelerated AMD PCNet Adapter #3 =========================================================================== =========================================================================== Active Routes: Network Destination Netmask Gateway Interface Metric 0.0.0.0 0.0.0.0 66.166.166.166 66.166.166.134 10 10.0.1.0 255.255.255.0 10.0.1.51 10.0.1.51 10 10.0.1.51 255.255.255.255 127.0.0.1 127.0.0.1 10 10.0.5.0 255.255.255.0 10.0.5.1 10.0.5.1 10 10.0.5.1 255.255.255.255 127.0.0.1 127.0.0.1 10 10.255.255.255 255.255.255.255 10.0.1.51 10.0.1.51 10 10.255.255.255 255.255.255.255 10.0.5.1 10.0.5.1 10 66.158.135.128 255.255.255.248 66.166.166.134 66.158.135.134 10 66.158.135.134 255.255.255.255 127.0.0.1 127.0.0.1 10 66.255.255.255 255.255.255.255 66.166.166.134 66.166.166.134 10 127.0.0.0 255.0.0.0 127.0.0.1 127.0.0.1 1 224.0.0.0 240.0.0.0 10.0.1.51 10.0.1.51 10 224.0.0.0 240.0.0.0 10.0.5.1 10.0.5.1 10 224.0.0.0 240.0.0.0 66.166.166.134 66.166.166.134 10 255.255.255.255 255.255.255.255 10.0.1.51 10.0.1.51 1 255.255.255.255 255.255.255.255 10.0.5.1 10.0.5.1 1 255.255.255.255 255.255.255.255 66.166.166.134 66.166.166.134 1 Default Gateway: 66.158.135.129 =========================================================================== Persistent Routes: None If I trace i got: Tracing route to 10.0.5.44 over a maximum of 30 hops 1 4 ms <1 ms <1 ms wxp-016.ad.baultar.com [10.0.1.51] 2 * * * Request timed out. 3 * * * Request timed out. 4 * * * Request timed out. 5 ^C I think the Internal computer NIC do not say what to do with this ip 10.0.1.51 I manually add a route to this local computer: route add 10.0.5.0 MASK 255.255.255.0 10.0.1.51 same result. Need help! Thanks
RE: 3-Leg Configuration problems - Help - 2.Oct.2008 5:03:31 PM
pdsavard
Ok its start working... My access rule are pointing to Internal and DMZ network. I read in the best practise that we MUST use computer name, subnet or other network object to correctly route. After changing the 2 Network in the access rule by 2 Computer object. I can ping from DMZ to internal but from Internal to DMZ I can't! The 2 access rule are identical. Any suggestion?
