407 Auth Required
All Forums >> [ISA Server 2004 Cache] >> Web Proxy client >> 407 Auth Required Page: [1]
407 Auth Required - 13.Oct.2009 6:17:04 AM
chrismyerz
Some of my client pcs running IE 7 are having a strange problem when using the ISA 2004 proxy (as proxy client).
Proxy settings are configured via GPO - using the hostname as the proxy address (e.g. PROXYSERVER) port 80
ISA rule is configured to allow All Auth'd users Web access via proxy.
The problem with some of the pcs, is that they get a prompt for credentials, which the correct DOMAIN\Username & password are supplied, 3 or 4 times and then a Network Access Message stating that Authentication is required Error 407 etc.
Looking at the ISA logs, it seems that the IE client is trying to auth anonymously.
However if I change the proxy settings in IE to the proxy servers IP address (or add an entry to the hosts file, same HOSTNAME and IP). it works fine!!
DNS/WINS is working ok as the traffic hits the ISA server in the first failed anon attempt.
Any ideas??
RE: 407 Auth Required - 13.Oct.2009 11:04:43 AM
Rotorblade
Port 80? Did you mean: 8080?
Try using the FQDN of the proxy server. It could be that your ISA NIC bindings are not properly ordered?
http://www.isaserver.org/tutorials/Configuring_ISA_Server_Interface_Settings.html
HTH
RB
David Melvin
Ohio
(in reply to chrismyerz)
