550 Access denied on uploading with FTP using ISA 2004 Firewall
All Forums >> [ISA Server 2004 Firewall] >> Firewall Client >> 550 Access denied on uploading with FTP using ISA 2004 Firewall Page: [1]
550 Access denied on uploading with FTP using ISA 2004 ... - 14.Mar.2005 4:28:00 AM
kritt
Why I can't upload content using FTP with ISA 2004 Firewall client ? It shows these errors :
550 Access is denied.
ERROR:>Requested action not taken (e.g., file or directory not found, no access).
When I change firewall client to another ISA 2000 Server it works fine.
The ISA 2004 is running on Windows 2003 and configured to allow unlimited internet access for anyone (Edge firewall network configuration).
Please help.
RE: 550 Access denied on uploading with FTP using ISA 2... - 14.Mar.2005 9:15:00 AM
ianfermo
Configure FTP and disable read only mode on your ISA Server 2004 console.
Cheers,
(in reply to kritt)
RE: 550 Access denied on uploading with FTP using ISA 2... - 14.Mar.2005 11:05:00 AM
Pilly
I just had this.
I agree with the agove, goto the rule, right click select Configure FTP and uncheck read only mode
(in reply to kritt)
RE: 550 Access denied on uploading with FTP using ISA 2... - 14.Mar.2005 11:22:00 AM
kritt
Thank you very much.
It's ok now.
(in reply to kritt)
RE: 550 Access denied on uploading with FTP using ISA 2... - 23.Mar.2005 7:45:00 PM
bbaxter51
This is a known issue with isa 2004 and microsoft released a hotfix to take care of the problem so you dont have configure work-arounds.
Here's the link, you just have to call them to get it, very easy to install. Hope that helps.
http://support.microsoft.com/default.aspx?scid=kb;en-us;884580
(in reply to kritt)
RE: 550 Access denied on uploading with FTP using ISA 2... - 24.Mar.2005 2:06:00 AM
WyldWolf
bbaxter51,
I believe this is fixed in SP1. Also, this is not the cause of the issue described he simply needs to turn off the "read-only" attribute on the FTP filter.
(in reply to kritt)
RE: 550 Access denied on uploading with FTP using ISA 2... - 24.Mar.2005 9:04:00 PM
bbaxter51
I might have dove in to deep, to quickly.
Thank you.
(in reply to kritt)
RE: 550 Access denied on uploading with FTP using ISA 2... - 31.Mar.2005 6:04:00 PM
jerumball
How is this same problem resolved in ISA 2004 EE? I cannot seem to find the place where I should be unchecking the "readonly" box.
Thanks.
John
[ March 31, 2005, 06:05 PM: Message edited by: jerumball ]
(in reply to kritt)
RE: 550 Access denied on uploading with FTP using ISA 2... - 21.Jun.2006 5:14:48 AM
nhhung_80
Firstly, you must allow FTP traffic.
Double-click "allow FTP traffic" rule, enter protocol tab-> click filtering -> click configure FTP
Good luck!
*** Hung Nguyen ***
(in reply to jerumball)
RE: 550 Access denied on uploading with FTP using ISA 2... - 26.Jun.2006 12:37:37 PM
angelis
Many thanks gentlemen. I had a problem whereby my engineers and myself could view an ftp site folder on a remote ftp server, but could not create or rename folders. I created a server policy named 'ftp access out' and then unticked the box under configure ftp. Initially, I was confused as I had set the access out of the building to everyone anywhere... which is why I could view the folder. Presumably the specific 'ftp access out' adds to and allows configuration of, ftp access.
By the way.... I'm still using an isa2000 client with isa server 2004. Can anyone advise on whether it's worth the trouble installing isa client 2004 across the company... and where I can find the executable!!!
Thanks, Angelis
(in reply to kritt)
RE: 550 Access denied on uploading with FTP using ISA 2... - 1.Sep.2006 11:49:00 PM
Tooliedotter
I too am having this problem, being unable to upload any files to an FTP location. Here is exactly what I have in my Access Rule:
Access rule (label): FTP Outbound
Action: Allow
Protocol: Selected Protocols: FTP
To: External
Users: All Users
Schedule: 24x7
Content: All content
I right-clicked on the FTP protocol and unchecked the Read-Only attribute. It's still not working, and I don't know why. I have enabled outbound Internet traffic for all users so I don't know what else should be changed.
This is the feedback from the server when I try to upload a file using Van Dyke's SecureFX product:
i Transfer(00BE2948): Opening file 'xxx.html' for upload as 'xxx.html'.
> Transfer(00BE2948): PASV
< Transfer(00BE2948): 227 Entering Passive Mode (xxx,xxx,xxx,xxx,136,210).
i Transfer(00BE2948): Data connection 71AB3B91 connected.
> Transfer(00BE2948): STOR xxx.html
< Transfer(00BE2948): 550 Access is denied.
i Transfer(00BE2948): File xxx.html could not be opened by server: 550 Access is denied.
I did a clean install of SBS2003 and ISA 2004 with all the service packs. I was able to upload when I was using ISA 2000.
Can someone help me? This is work stoppage for me -- I am a web designer part-time and I have to use my dialup connection to upload files until this is fixed.
Toolie
Toolie
Tooliedotter, Inc.
(in reply to angelis)
RE: 550 Access denied on uploading with FTP using ISA 2... - 2.Sep.2006 2:22:15 AM
Tooliedotter
I finally figured it out; when I selected the Edge Network configuration, the Unrestricted access selection configured an FTP setup without me realizing it. I thought I needed to add another one, which is what is described above. When I realized that the template rule contained an FTP specification, I went in and found the still checked read-only setting, unchecked it, and voilą! Now it works.
Hopefully this will clue in others who might not have figured out the the template rule was the governing factor.
Toolie
(in reply to Tooliedotter)
RE: 550 Access denied on uploading with FTP using ISA 2... - 14.Jan.2009 4:55:20 AM
ska_defender
Hello I cant see any such option "goto the rule, right click select Configure FTP and uncheck read only mode"
When I open ISA 2004 client I have only a window in which only these options are there
Three tabs
General  Setting WebBrowser
There is no configure ftp option
Please help me I cant upload my files to my site
Please help!
(in reply to kritt)
RE: 550 Access denied on uploading with FTP using ISA 2... - 12.Mar.2009 8:14:44 AM
kchenthilk
I have One ticket regarding the FTP Uploading.
We have to dowload the files without problem.But when we upload the file in Mainframe FTPServer we have got the error 550:FTP Reported Fault Acces Denied.
We have also check the all the alter access for the user.That's No problems..
The OS is WindoesXP(SP2).
Help me..............
Thanks&Regards
K.Chenthil.
(in reply to ska_defender)
RE: 550 Access denied on uploading with FTP using ISA 2... - 12.Mar.2009 8:21:22 AM
SteveMoffat
You have enabled FTP Upload in the access rule?
Steve
www.isaserver.bm
(in reply to kchenthilk)
RE: 550 Access denied on uploading with FTP using ISA 2... - 12.Mar.2009 8:24:25 AM
kchenthilk
No.
How to i Enable the FTP access rule?
Can you help me..
Thank you in advance...
Regards
Chenthil
(in reply to SteveMoffat)
RE: 550 Access denied on uploading with FTP using ISA 2... - 12.Mar.2009 8:42:03 AM
SteveMoffat
Right click on the access rule, select configure FTP and remeve the tick from the read only box.
Steve
www.isaserver.bm
RE: 550 Access denied on uploading with FTP using ISA 2... - 12.Mar.2009 11:51:12 AM
SteveMoffat
PLEASE KEEP IT ON THE LIST.
Hi Steave,
 Thanks For your quick reply.
I can't find "Config FTP " Section in windows XP.
Regards
Chenthil..
http://forums.isaserver.org/m_270023900/mpage_1/key_/tm.htm#2002082853
[Message sent by kchenthilk@gmail.com via AddThis.com. Please note that the sender's email address has not been verified.]
Steve
www.isaserver.bm
RE: 550 Access denied on uploading with FTP using ISA 2... - 12.Mar.2009 11:52:49 AM
SteveMoffat
It's not on your XP machine, it's the access rule in the firewall policy on your ISA Server.
Steve
www.isaserver.bm
Post #: 19
