Active sync connection problem in ISA 2006
All Forums >> [ISA 2006 Publishing] >> Exchange Publishing >> Active sync connection problem in ISA 2006 Page: [1]
Active sync connection problem in ISA 2006 - 22.Jan.2007 11:39:09 AM
mjgraves@tisecurity.
Our OWA along with active sync was coming in from outside to internal on a PIX.  Having a fairly new ISA 2006 installed, I moved it to come in via ISA. So it is external to DMZ to ISA to Internal.
Web clients work with no problem, but active sync clients fail with 403 every time.
My path is set to external same as internal with internal as /*
I have checked active sync and mobile access in the publishing rule.
I set logging filters for specific client IP for testing, but the URL field is not showing.
< Message edited by mjgraves@tisecurity. -- 7.Feb.2007 10:27:27 AM >
Mark
RE: Active sync connection problem in ISA 2006 - 26.Jan.2007 1:44:11 PM
Do the clients have the certificates installed?
(in reply to mjgraves@tisecurity.)
RE: Active sync connection problem in ISA 2006 - 29.Jan.2007 8:30:05 AM
Tom,
Thanks for the reply. I have asked this, but will check more thoroughly.
This application worked to the same OWA when it was just behind the PIX, and SSL was required at that time.  But I will confirm again the settings of the mobile device.
Mark
RE: Active sync connection problem in ISA 2006 - 29.Jan.2007 8:29:42 PM
Hi Mark,
The PIX is just blindly passing the connections through, the ISA Firewall is terminating the connections. However, if blind SSL passthrough worked for those clients, it does indicate that the clients are configured correctly. In that case, you might want to check the rules and the certificates on the ISA Firewall.
RE: Active sync connection problem in ISA 2006 - 30.Jan.2007 10:14:58 AM
Tom,
I will do that. However the browser clients work fine. The same cert that was on the internal OWA box when just accessed via PIX is what I installed in on the ISA server.
It went fine into the cert store and ISA implemented it on the listener with no problems.  Browser clients work ok.
I will check again and look for anything obvious I may have overlooked.
This is  self-signed cert created on our domain.
Any specific logging I can turn on in ISA to gather more information?
Thanks.
Mark
RE: Active sync connection problem in ISA 2006 - 30.Jan.2007 10:39:28 AM
Are the OWA and ActiveSync Web Publishing Rules using the same Web listener?
Are there two rules or one rule?
Maybe there's a configuration error in the rule.
RE: Active sync connection problem in ISA 2006 - 30.Jan.2007 1:59:26 PM
The OWA and Active sync are the same rule with the same listener and obviously the same Cert.
The are both hitting the same internal machine, so I figured the same listener.
Mark
RE: Active sync connection problem in ISA 2006 - 31.Jan.2007 11:19:27 AM
Hi Mark,
Try running the ISA Firewall BPA and see if that helps.
Also, what device are you running ActiveSync on? Windows Mobile or SmartPhone?
RE: Active sync connection problem in ISA 2006 - 31.Jan.2007 11:35:42 AM
Tom,
Thanks for the quick response. I have done that, but it has been while. I will do so again.
One client is a smartphone and one is a Palm.
ISA is not handling authentication, but the rule was set for "client cannot authenticate directly."  I changed it this morning to "client can authenticate directly."
This had no bearing on browser clients, but possibly could on the mobile devices.
I am waiting for test results.
Mark
RE: Active sync connection problem in ISA 2006 - 31.Jan.2007 11:47:23 AM
Hi Mark,
One of the major security benefits of using the ISA Firewall for OWA and Mobile access is pre-authentication at the ISA Firewall in order to prevent anonymous attacks against the Exchange Server. You might want to consider auth'ing at the ISA Firewall in the future to shore up your network security design.
RE: Active sync connection problem in ISA 2006 - 31.Jan.2007 1:51:28 PM
Yes, I plan to do that. It is a gradual change in our architecture, of which ISA is a big part.
I got ISA implemented mainly for Sharepoint and am now moving more other web apps behind it.
I am very pleased with it.
Mark
RE: Active sync connection problem in ISA 2006 - 7.Feb.2007 10:26:35 AM
Tom,
The rule change took care of the problem.
Thanks for the help.
Mark
Mark
RE: Active sync connection problem in ISA 2006 - 7.Feb.2007 11:30:26 AM
Hi Mark,
What change did you make to get it to work?
RE: Active sync connection problem in ISA 2006 - 13.Feb.2007 3:25:26 PM
Sorry for the delay.
Changing to "client is allowed to authenticate directly" took care of the problem.
Again, I  know this is not ideal, and I am working on changing that.
Thanks for the excellent and friendly help.
Mark
Mark
RE: Active sync connection problem in ISA 2006 - 14.Feb.2007 11:01:57 AM
Hi Mark,
Got it!
RE: Active sync connection problem in ISA 2006 - 5.Mar.2007 3:24:34 PM
patos
Hi!
Just a quick tip for your smartphones.
If you are using a self-signed certificate, you will eventually have to deal with getting the root certificate into the smartphones (or any other windows-based devices for that matter). activesync will not like syncing over SSL based on a PKI it doesn't trust. But i guess you have already noticed this in some way. =)
In mobile 2003 you could do a simple reghack on the phone to make it ignore the cert validation error, but in 2005 it's a bit harder. And now with mobile 6 on the way i would really get my stuff together.
The simplest test is always to use the webbrowser in your phone and try to connect to the OWA website. If no warnings there, then the certificates are
ok for your device.
RE: Active sync connection problem in ISA 2006 - 6.Mar.2007 11:22:52 AM
Hi Patos,
I haven't had a chance to play with WM6 yet, but from what I read, the certificate manaagement process is supposed to be a lot easier. And one piece of very good news is that WM6 is supposed to support Wildcard Certs on the Web listener! Yay!!
(in reply to patos)
RE: Active sync connection problem in ISA 2006 - 6.Mar.2007 6:11:11 PM
patos
Well we'll just have to wait and see. I'm sure some of them will come our way at work. We do a lot of work with cellphones. Unfortunately, all these non-disclosure agreements makes it hard to know what you can say and not say though.
