Allowing port 4662
All Forums >> [ISA Server 2000 Firewall] >> Firewall Client >> Allowing port 4662 Page: [1]
Allowing port 4662 - 11.Nov.2003 9:11:00 PM
Eradicator2003
Hey folks ,
I've got the ISA installed ,and it blocks the softwares that use port 4662. How can I configure it to allow downloads and connection through this port??
RE: Allowing port 4662 - 11.Nov.2003 9:33:00 PM
Hi Eradicator,
check out http://www.tacteam.net/openport.htm ! [Big Grin]
You have to create a protocol definition unless it is an unstandard HTTPS port. So, to help you further you have to give us some more info.
Is it HTTP, HTTPS, TCP or UDP based? Who initiates the connection (inbound or outbound)? etc...
Once the protocol definition is created you have to allow it in a protocol rule.
(in reply to Eradicator2003)
RE: Allowing port 4662 - 11.Nov.2003 9:49:00 PM
Eradicator2003
Thanks! You've already helped me so much!
I'm using the emule software ,actually..
Frankly ,I'm very novice-y in the ISA stuff ,so I don't know to distinguish between inbound and outbound. I think it uses TCP protocol ,if it helpes in some way...
RE: Allowing port 4662 - 11.Nov.2003 10:30:00 PM
Hi Eradicator,
it sounds like the eMule software is some kind of P2P Filesharing application. I suggest you do a search in all the forums on the keyword "emule". There seems quite a lot of posts about this software.
