munnobhai
Several months ago I have submitted a topic in tips & tricks named BEST ISA SERVER CONFIGURATION and after that too many people contacted me and asked me to share those settings and I promised to do so as soon as possible but I never got time to do it àsorry for that. But now as IÆm free a little bit because of our holy month of Ramadan so IÆm accumulating my knowledge as being a cable net administrator and knowing the requirements for a cable net user. Most of new comers to ISA Server complains about that www.isaserver.org has too much info, tips and Q&A (which are valuable resources) however it does not help a new comer to take an instant stand and then understand what is going on by walkthroughs and some subject oriented ISA Server configurations. So IÆm starting with a such one as the title indicates. Install Windows 2000 Server or Advanced Server and install the following too: 1.Internet Explorer 6 SP1 or Later. 2.Service Pack 4 or Later. 3.Updated Antivirus (Norton Antivirus Corporate Edition recommended because it is light and effective). 4.Update Windows with all critical updates. 5.Install a third party firewall (Sygate Personal Firewall Pro recommended because it has the functionality to block the communication on MAC address basis and effective firewall). I recommend this step for advanced users only as wrong configuration leads you to services not working. 6.Install a bandwidth monitor like DU Meter or configure MRTG for your Internet connection. (I have both). As ISA Server could be installed on domain controller as well as on standalone pc here is the first tip for a LAN administrator: donÆt use a domain unless you want to run logon scripts on users accounts (you will save too many resources when installing ISA Server on standalone server). Installing ISA Server is not discussed here but for those who canÆt do that too just press next next till you finish the setup. When setup ends it will start the wizard for ISA Server configuration just press the finish button without configuring through Wizard. After that go to tools bar and click on view then select advanced (doing this will change the gui on right side of the ISA Server Management). I have created/edited some scripts to make configuration of ISA Server much easier and faster thanks to people like Jim Harrison and others on www.toolzz.com . IÆm uploading these scripts too but if you want to download it then go to http://207.226.41.252:83/scripts.zip . These scripts are as follow : 1.Create content group (to make a complete content group for downloads blocking). 2.Set Application Settings (to block KAZAA type applications , block multi msn and some spy ware applications, which wastes bandwidth). 3.Java Sites (to make a destination set for some always allowed downloading destinations like web sms sites and yahoo games and chat rooms). 4.Mail Sites (to make a destination set for some sites to not cache to guarantee its content freshness). 5.Enable Routing (to make cache response faster in peek hours). 6.Disable Routing (to back to normal to keep cache contents fresh). Close ISA Server Management and run top four scripts (Create content group, Set Application Settings, Java Sites and Mail Sites). Now open ISA Management again and do these fast steps: 1.Go to Access Policy and expand it and right click on Protocol Rules and select New then Rule.. A new protocol wizard will start name it ALLOW ALL and press next next till the wizard ends. Now right click on Site and Content Rule and select new rule and name it ALLOW ALL (if there is any previous rule remove it) then press next and tick on Allow then press next next till wizard ends. Now right click on IP Packet Filters and select properties, a new window will open , remove the check from Enable Packet Filtering , press apply and the OK. 2.Under servers and arrays you will see your server name , right click on it and select properties. Go to Outgoing Web Requests and tick on Configure listeners individually per IP address . Then put check mark on Enable SSL listeners, above this check mark you will see a button captioned Add.. press it. A new window will open , select your server name from the server combo box and select LAN IP address for your server from the IP address combo box. Remove the check from integrated a warning message will be there just press OK and repeat these steps again but this time with loop back IP Address (127.0.0.1) in IP address combo box. After pressing OK you will see two IP addresses in the space above Add.. button. Now get out of it by applying and pressing OK. 3.Go to Client Configuration , you will see Web Browser and Fire Wall Client on your right. Double click on Web Browser then in place of DNS name put your ServerÆs IP address and press OK. Now double click on Fire Wall Client and tick on IP Address rather than DNS name. Press OK. 4.Right click on H.323 Gatekeepers and select Add gatekeeper.. a new window will open , press OK. 5.Go to Network Configuration and expand it , right click on Local Address Table and select Construct LAT.. a new window will open , remove the first check and put check on local area interface IP address and press OK. Now right click on routing and select New then Rule.. a new window will open , set the routing rule name as Other Sites and press next , then select from combo box All Destinations Except Selected Set and below that there is another combo box ,select Mail Sites from it, press next ,Request Action window will appear ,leave it as default and press next , Cache Retrieval Configuration window will appear , select the second option (any version of the objectà) press next ,Cache Content Configuration window will appear ,leave it as default and press next then press finish. We have to make another routing rule for Mail Sites , so right click on Routing and select New then Rule and name it Mail Sites ,press next then select from combo box Specified Destination Set , a new combo box will appear below ,select Mail Sites from it and press next next till wizard ends. 6.Go to Extensions and expand it then left click on Application Filters , some filters will appear on the right ,right click on SOCKS V4 Filter and select Disable, then right click on HTTP Redirector Filter, a new window will appear select options tab then tick on the last option (Reject HTTP requests fromà.) and press OK. 7.Go to Monitoring Configuration and expand it, then right click on Report Jobs and select New then Report Job , a new window will appear , select schedule , under Start Report Generation select At tomorrows date and set a suitable time like 12:00 , below Recurrence Pattern select Generate every day , If ISA Server installed on a Domain Controller then set the credentials by selecting Credentials tab and entering Administrator ID and Password and domain name. 8.Go to Cache Configuration and expand it then select Drives , you will see server name and cache size on your right , double click on it and set the cache size minimum of 1GB.(tip : try to build cache on a separate drive (physically) means hard drive other than the one which has the operating system on it and build cache as large as you can).After setting the cache size right click on Cache Configuration and select properties, a new window will appear , select HTTP tab , put check on Enable HTTP caching and tick on fourth option (Set Time To Live..) and enter 999 in This percentage of content age , and set 2 hours in No less than combo box and 6 hours in No more than combo box , Select FTP tab , and put check on enable FTP caching and set the time to live for all objects to 2 Days (you can increase the time), Select Active Caching and enable Active Caching and tick on Less frequently , and in last tab Advanced you have four check boxes , put checks on second and fourth boxes and remember to remove the checks from the first and third boxes. Press OK. 9.Go to Policy Elements and expand it and right click on Client Address Sets and select New then Set and name it LAN and enter IP range of your LAN (like 192.168.0.1-192.168.0.254). Make another set and name it VIP and enter an IP address (the IP addresses which are allowed to download all the time, first of all put serverÆs IP address). 10.Right click on Schedule and make a schedule suitable for your network (in my own network I blocked the downloads from 6PM-1AM and all Sundays). 11.Right click on Bandwidth Priorities and select New then Bandwidth Priority.. name it Messengers and enter Outbound and Inbound bandwidth as 200 and press OK , make another one with the name of Browsing and set both Out and Inbound to 100 , then edit the Default Bandwidth Priority and set it to 1 , press OK. 12.Go to Bandwidth Rules and right click on it and select New then Rule and name it Messengers, press next , from Apply this rule to combo box select selected protocols and put checks on all your favorite messengers (like AOL,MSN,ICQ etc..) press next , leave the Schedule as default and press next ,leave Client Type as default and press next ,leave Destination Set as default and press next ,leave Content Group as default and press next, in Bandwidth Priority window tick on custom and select Messengers from Name combo box and press next then Finish. We have to make Bandwidth Rules for Downloading and Browsing too so make another Bandwidth Rule and name it Browsing and select these protocols (HTTP,HTTPS) and in HTTP contents select (Documents, HTML Documents, Images and Text) and set the bandwidth priority to Browsing , leave all unmentioned tabs as default. And finally make Another Bandwidth Rule and name it Downloading and select these protocols (All HTTP and FTP protocols) and in HTTP Contents select (Downloads) and set the bandwidth priority to Default Bandwidth Priority and press finish. 13.Now we have to block Downloading (as scheduled) , go to Access Policy and then make a new Site and Content Rule , name this rule as Block DL and press next , tick on fourth option (custom) and press next, select from Apply this rule to: combo box All destinations except selected set and select Java Sites from Name combo box , press next ,in Schedule window select the schedule you have set in Policy Elements, press next, in Client Type window select second option (Specified Computers..) , press next ,in Clients Sets windows press Add button then add LAN and press OK then next, in Content Group window tick on Only the following content types: and put check on Downloads , and press next and finish. Double click on the crated rule and select Applies to tab and below in Exceptions add VIP then press OK and OK again. 14.Right click on Protocol Rules and make a new rule and name it Block FTP , set the action to deny, and protocols to all FTP protocols, set the schedule as you set it in Policy Elements and set the Applies To: to LAN with Exceptions to VIP as We did in Block DL rule
Now we have completed the configuration still we have to schedule to run scripts (Enable Routing , Disable Routing) on regular basis . First copy these scripts to a safe location then go to schedule tasks in control panel and add tasks as follows: Enable Routing.vbs at 12:00 every day Disable Routing.vbs at 18:00 every day Enable Routing.vbs at 21:00 every day Disable Routing.vbs at 04:00 every day This is what I found the best configuration a cable net operator could have as IÆm running it on my network I rarely found An un satisfied user , I will be waiting for comments from all of you and we will continue to discuss why,what,where of this Configuration. I tried to make the walkthrough easier for new users of ISA Server and It looks like a mess but anyway it was best of mine.
Hunaid Haroon Al Qureshi A-42 Block 16 Federal B Area Karachi , Pakistan. Tel:-6622962, 0333 2219022 munnobhai@hotmail.com
