Building my own two factor authentication
All Forums >> [ISA Server 2000 Misc.] >> ISA Server Programming >> Building my own two factor authentication Page: [1]
Building my own two factor authentication - 3.Jan.2004 3:17:00 PM
Ole Kristian
Hi!
I want to add two factor security to some of my published servers, say citrix secure gateway and lotus domino webmail. I have looked at some of the solutions out there, but they are rather expensive. So I thought why not build our own?
What I want to do is restrict access to the published servers through a combination of windows 2000 domain/username and a one time password. This one time password will be generated at the server, and sendt to the users mobile phone on request. The mobile phone numbers will be stored in the user profiles. I have the means to generate and send the passwords, but how do I block or open a session against a published server on the isa server?
I could of course block all access to the published server by default, and open the published server for access by the ip address of the user. But this is not an optimal solution as it would also open the published server to any user behind a nat network using the same official ip address.
I hope this was not to confusing, and would really appreciate all help.
- Ole Kristian
RE: Building my own two factor authentication - 8.Jan.2004 5:37:00 AM
Jim Harrison
You'll easily spend more development and test money "rolling your own" than by purchasing a pre-existing solution...
(in reply to Ole Kristian)
RE: Building my own two factor authentication - 9.Jan.2004 10:23:00 AM
Ole Kristian
I get your point, but I'm not sure that it is true in this case. A cheap token like SafeWord for citrix will set me back 99$ per user, even with discounts this would be costly with 500 users. Also, depending on the programming features of ISA server I don't think that this task is that hard to do. All you need to do is figure out a way to disconnect or allow an incoming session against one of the published servers programatically. The rest is no problem..
T. Shinder, any comments on this?
- Ole Kristian
RE: Building my own two factor authentication - 14.Jan.2004 2:24:00 AM
Jim Harrison
Have you examined the Feature Pack 1 SecurID solution?
It costs you $0 for the initial license and $0 per user thereafter.
http://www.microsoft.com/downloads/details.aspx?FamilyID=2f92b02c-ac49-44df-af6c-5be084b345f9&DisplayLang=en
RE: Building my own two factor authentication - 18.Jan.2004 10:11:00 PM
Ole Kristian
Thanks for your input, but according to the FP1 documentation:
Using the Web filter for authentication for RSA SecurID, you can authenticate users, based on authentication credentials from the SecurID product from RSA.
This indicates that I need the RSA ACE/Server, and that the featurepack only supplies the integration with the product. RSA ACE/Server is far from free..
- Ole Kristian
RE: Building my own two factor authentication - 12.Jul.2005 4:53:00 AM
crosljam
Just for interest how did you get on with this - just started looking at 2 factor authentication and running into the same money issues!
Cheers, James
RE: Building my own two factor authentication - 23.Oct.2005 2:56:00 PM
Ole Kristian
I have decided to go with the safeword solution. I have not the time to investigate this further, allthough I think my idea of using random passtokens sendt to the users mobile phone can be done securly. I think maybe the way to go would be to integrate the citrix webinterface/secure gateway against a radius server that reads the randomly generated passwords from a database.
- Ole Kristian
RE: Building my own two factor authentication - 2.Dec.2014 3:45:35 AM
maya628
I am trying to load the sample WebResponseModifier given along with Microsoft Platform SDK. The dll gets loaded but when I try to access any link through the proxy, the web filter is not invoked.
