Changed to multi-homed configuration to include DMZ networks
All Forums >> [ISA Server 2000 Firewall] >> DMZ >> Changed to multi-homed configuration to include DMZ networks Page: [1]
Changed to multi-homed configuration to include DMZ net... - 24.Feb.2006 5:38:33 PM
PCC
I recently change my edge firewall setup to a multi-homed setup to include a Anonymous DMZ network, NIC IP address is 172.16.0.1, and a Anonymous WAP network, NIC IP address is 10.0.0.1.  Ever sense this change I have been getting two errors when the firewall service starts up.
ISA Server detected routes through adapter External that do not correlate with the network element to which this adapter belongs. For best practice, the address range of an ISA Server network should match the address ranges routable through the associated network adapter as defined in the routing table. Otherwise valid packets may be dropped as spoofed. (This alert may occur momentarily when you create a remote site network. You may safely ignore this message if it does not reoccur.) The address ranges in conflict are: 172.16.1.0-172.16.255.255;.
And this one
ISA Server detected routes through adapter Anonymous DMZ that do not correlate with the network element to which this adapter belongs. For best practice, the address range of an ISA Server network should match the address ranges routable through the associated network adapter as defined in the routing table. Otherwise valid packets may be dropped as spoofed. (This alert may occur momentarily when you create a remote site network. You may safely ignore this message if it does not reoccur.) The address ranges in conflict are: 172.16.1.0-172.16.255.254;.
I have a NAT network rule for "Internal to Anonymous DMZ". I also have one ftp server and one HTTP server published in the Anonymous DMZ  on the same physical server with IP address 172.16.0.2.  Do I need to add a network rule for "External to Anonymous DMZ" via NAT as well?
Thanks.
