Cisco pix and isa 2004 ipsec wierdness
Cisco pix and isa 2004 ipsec wierdness - 1.Nov.2005 6:58:00 PM
aaronsb
I'm managing a remote site that connects to a cisco pix concentrator. I don't know much about the cisco end, other than chatting with the admin over there. However, here's where it gets a little strange.
There's a web server on the far end of the tunnel, and we've established an ipsec connection fine. You can see the protocol in a network trace, and you can ping machines on the far side as well.
However, it appears as if there are no open tcp or udp ports on any machines at the far end. ICMP returns fine however. The firewall rules are configured for completely open to the ipsec connection from the internal lan.
After beating myself up on the problem for a while, I was performing another packet trace when I saw someone else in the office successfully connecting to the site. (I've got split dns inside the lan to point to the site)
I hurried over to the machine to see why they could connect, and it ended up that they have a cisco vpn connection app installed on their machine.
Only machines that have that app installed can successfully connect to resources through the tunnel. I installed (but did not run) the vpn app on my machine, and after a reboot I could access the page and see open network ports.
After I uninstalled the app, I could still connect to the remote resources.
I am thinking about installing the vpn connection app on the isa server to see if it provides the connectivity I need to the rest of the network clients, but I'm wary as to what the heck this thing is doing to the network stack to make things work.
Has anybody experienced this and/or have suggestions as to configure isa to work without creepy software?
Aaron
