Citrix/Nfuse publishing problem
All Forums >> [ISA Server 2000 General] >> Server Publishing >> Citrix/Nfuse publishing problem Page: [1]
Citrix/Nfuse publishing problem - 24.Jan.2002 3:12:00 PM
rtmorgan
Let me start off by saying that I got my Citrix server published initially by following the Learning Zone article on this site. It was very well done and easy to follow.
Now for my problemà This is an intermittent problem and those are always the hardest to fix. What happens is that about 50% of the time when you try to connect to my server by the Program Neighborhood or NFUSE it will work correctly. The other 50% of the time it will ôlock upö. When it does not work with NFUSE it will get hung at the Windows screen. You can see the Citrix logo, but the system never fully logs you on. If it fails when you try the program neighborhood it will give you a login screen and when you hit OK or Enter it will just freeze.
The system works perfectly if you connect from the local network. This leads me to believe that it has to be an ISA issue of some kind. Any help would be greatly appreciated.
One last note is that I now have MetaFrame XP. This problem also existed when I was using 1.8.
Thanks for reading,
Rusty
