Citrix PS4/XPe and ISA 2006 EE
All Forums >> [ISA 2006 Publishing] >> Server Publishing >> Citrix PS4/XPe and ISA 2006 EE Page: [1]
Citrix PS4/XPe and ISA 2006 EE - 3.May2007 12:31:25 AM
dano2300
A bit of a newbie question,......
I have at the moment 1 ISA 2006 EE server in my DMZ.  I would like to publish / allow access to my PS4 / XPe farm through the ISA server.  I have created an access rule that allows ICA from the ISA server to the citrix server(s).  From the ISA server I can telnet to one of the citrix servers on port 1494.  I have also opened up port 80 and 443 and I can make it to the web interface that is published on a sharepoint page off of a different server.  I can not connect to the citrix server through the ISA server.  The ica connection just times out.
Do I need to change the default gateway of the citrix servers to point them to the ISA server?
Does anyone have any good documentaion on how to publish / allow access to Citrix servers through ISA 2006?
Thanks  all !!!
RE: Citrix PS4/XPe and ISA 2006 EE - 18.Jul.2007 3:16:06 PM
Jool73
You must add a static route to your Citrix server or change default gateway to ISA server, start with that.
/Jonas
(in reply to dano2300)
RE: Citrix PS4/XPe and ISA 2006 EE - 29.Aug.2007 2:28:10 PM
aavdberg
Use the free Citrix Secure Gateway and run this on a machine that is located in a DMZ and install on this same machine Citrix Web Interface and the CWI will connect to your citrix farm.
This is the best working model i think, we are doing it like this.
Greeting from
André van den Berg.
(in reply to Jool73)
RE: Citrix PS4/XPe and ISA 2006 EE - 16.Oct.2007 3:43:24 PM
Typoman
I just dealt with publishing my citrix server through ISA2006.  I read microsoft's documentation that says to make the citrix server a SecureNAT client of the ISA server.  I did that and added static routes on the citrix server for all of my private LANs.  This worked perfectly.
I found another solution that works in my setup.  I leave the citrix server's gateway at the same one that the rest of the network uses.  I do not add static routes to the citrix server.  I modify the server publishing rule in ISA to make "Requests appear to come from the ISA Server computer".  This is on the "To" tab.
(in reply to aavdberg)
