Citrix Serve behind ISA partially works
All Forums >> [ISA Server 2004 Firewall] >> Access Policies >> Citrix Serve behind ISA partially works Page: [1]
Citrix Serve behind ISA partially works - 8.Sep.2004 10:44:00 PM
urbman
I followed the tutorial on how to publish a citrix server behind an ISA, everything seemed to be working fine. I goto http://isa external ip addres/citrix/metaframe/default.htm and log in. I am them presented with all my icons and such. I try to run one of the published application and I get a message about the "there is no citrix server configured on the specified address". So I begin the troubleshooting process. Seems to me the altaddress must be wrong. but I ran the command twice with no luck. I then decide to try looking at the launch.ica file. It uses the internal ip address of the Citrix server. I suspect that this is the problem since there is no way a computer on the internet can know the private ip range. I tried manually altering the file putting in the correct ip but no luck. same error message. Here is the info in the launch.ica
[Encoding]
InputEncoding=ISO8859_1
[WFClient]
Version=2
ClientName=username
TransportReconnectEnabled=On
RemoveICAFile=yes
[ApplicationServers]
Citrix Server=
[Citrix Server]
Address=??? ---:1494
InitialProgram=#Citrix Server
LongCommandLine=
DesiredColor=4
TransportDriver=TCP/IP
WinStationDriver=ICA 3.0
AutologonAllowed=ON
Username=username
Domain=\753FC49A34B978DD
ClearPassword=3258232EBD4099
ClientAudio=On
DesiredHRES=1024
DesiredVRES=768
TWIMode=Off
SessionsharingKey=4-basic-basic-username-W2K Server
