Client SSL certificate problem
All Forums >> [ISA 2006 Publishing] >> Web Publishing >> Client SSL certificate problem Page: [1]
Client SSL certificate problem - 9.Oct.2006 9:17:36 AM
sebrin
I have some problem with client certificates.
On the ISA server I require the user to use client certicates. When I try to access the webbsite trought ISA server I get a popup windows where I shuld choose certificate to use, but the box is empty. I have some certificates installed and can use them on other sites but when trying them trought ISA server I donīt get it to work.
Any clues ?
RE: Client SSL certificate problem - 11.Oct.2006 9:51:26 PM
Hi Sebrin,
When using User Certificate authentication, are you using KCD as well?
Also, make sure the clients trust the User Certificates that are installed on them and that the ISA Firewall trusts the User Certificate is presented by the client.
(in reply to sebrin)
RE: Client SSL certificate problem - 12.Oct.2006 5:31:45 AM
sebrin
Thanks for the reply
I found my configuration mistake. I tried to use a free certificate that didnīt match my username. Found the answer in one of your articles.
Best Regards
Sebrin
