Client authentication help
All Forums >> [ISA Server 2000 Firewall] >> General >> Client authentication help Page: [1]
Client authentication help - 18.Jun.2003 4:50:00 AM
gigabit
ISA is requesting authentication from users even though authentication is not required. I am using integrate authentication, and this only happens to one group of users with a restricted dest. set. Can anyone help? I am sure it is something small that I am overlooking. All I need is to make sure that these users are not asked to authenticate. OH if you use the users crdentials to authenticate it doen't work, only the admin account will allow the web access.
RE: Client authentication help - 18.Jun.2003 7:38:00 PM
Hi Gigabit,
check out http://support.microsoft.com/default.aspx?scid=kb;en-us;297324 . Just make sure ISA server is running SP1 and you manually create the ReturnDeniedIfAuthenticated registry value as indicated in the KB.
(in reply to gigabit)
RE: Client authentication help - 18.Jun.2003 7:47:00 PM
aselicean
Thank you Stefaan
I was having the same problem. Now seems to be solved.
Cheers,
RE: Client authentication help - 18.Jun.2003 9:33:00 PM
Hi Alin,
glad I could help! [Smile]
RE: Client authentication help - 18.Jun.2003 11:23:00 PM
gigabit
Stefaan,
Thanks. I already have sp1 installed. I think the problem was on how the destination set was configured. I took care of the problem, but now my users get to their website and all of the sudden they are asked to authenticate if they click on a link. Can I use * after .com(ex. *.microsft.com/*. They can cancel the authentication, but the page does not come up compltete. Any ideas?
Thanks for the help.
RE: Client authentication help - 18.Jun.2003 11:45:00 PM
Hi Gigabit,
running ISA SP1 is a requirement, *but* you still have to add that registry key *manually*! That will take care of authorized web pages which contains embedded objects from unauthorized web pages.
RE: Client authentication help - 19.Jun.2003 2:57:00 AM
gigabit
Thank you sir. I did forget to do that.
RE: Client authentication help - 19.Jun.2003 8:06:00 PM
Hi Gigabit,
RE: Client authentication help - 19.Jun.2003 9:37:00 PM
gigabit
Stefaan,
Now I get a 407 error.
RE: Client authentication help - 19.Jun.2003 9:52:00 PM
Hi Gigabit,
did you restart the web proxy service after applying the registry change? If it still doesn't work as expected, can you give us the URL for such a site?
