Client may delegate directly - Basic > NTLM
All Forums >> [ISA 2006 Publishing] >> Web Publishing >> Client may delegate directly - Basic > NTLM Page: [1]
Client may delegate directly - Basic > NTLM - 11.Jan.2008 12:03:43 PM
sammannix
Hello,
I have a web listener which uses Basic Authentication. When publishing to a website which requires integrated authentication, and the delegation option set on the firewall rule to ...but client may authenticate directly, but rule is still denied even when inputting correct credentials. I found through a trace it seems ISA is trying to authenticate to the website using Basic instead of NTLM.
The ISA server can't be a member of a domain, so Integrated can not be used on the listener.
Is this feasibly not possible?
Thank you
Sam
RE: Client may delegate directly - Basic > NTLM - 29.Jan.2008 6:53:57 AM
Join the ISA Firewall to the domain to get the NTLM functionality and increase security. It's a very poor security decision to not join the ISA Firewall to the domain. You might want to warm whoever made that decision that it's not the best security configuration and they should revisit their security design documents.
(in reply to sammannix)
