Clients bypass HTTP filter
All Forums >> [ISA Server 2004 Firewall] >> HTTP Filtering >> Clients bypass HTTP filter Page: [1]
Clients bypass HTTP filter - 24.Dec.2004 12:57:00 AM
muntos
So we are using ISA 2004 on Win 2003 Server.
ISA is configured to allow Internet access only to authentificated users and is configured to allow both Firewall clients and Web Proxy clients.
We also use SurfControl to restrict access to certains sites.
The problem is that if the users remove web proxy settings in LAN connections on IE they can gain access to restricted sites since the authentification is made by firewall client.
So,how we can prevent this behavior ?
Thanks ?
RE: Clients bypass HTTP filter - 24.Dec.2004 3:59:00 PM
Hi Muntos,
All connections made by the Firewall client are passed to the Web Proxy filter when the Web Proxy filter is bound to the HTTP protocol, so they cannot bypass the Web Proxy when configured as Firewall clients.
Also, make sure your access rules require authentication, so that they cannot use the SecureNAT client config.
(in reply to muntos)
RE: Clients bypass HTTP filter - 24.Dec.2004 6:45:00 PM
muntos
"All connections made by the Firewall client are passed to the Web Proxy filter when the Web Proxy filter is bound to the HTTP protocol, so they cannot bypass the Web Proxy when configured as Firewall clients."
Seems to me that's what I need,but I have a problem: how do I bound the Web Proxy filter to the HTTP protocol,or how can I verify this ?
RE: Clients bypass HTTP filter - 24.Dec.2004 10:03:00 PM
muntos
"There is still value in configuring the clients as Web Proxy clients. While the Firewall client connections will be forwarded to the Web Proxy component when the Web Proxy filter is bound to the HTTP protocol (which it is by default)"
taken from other thread.
So if I understand good this bound is by default,then whats wrong in our configuration?
There are only rules that requires authentification,but when the clients remove proxy settings from their browsers they can access restricted sites ? Why ?
RE: Clients bypass HTTP filter - 27.Dec.2004 2:38:00 PM
muntos
Ok,I've verified HTTP protocol and he's bound to Web Proxy filter !
Any ideas please ?
RE: Clients bypass HTTP filter - 28.Dec.2004 3:46:00 PM
BlackPH
It and the truth so, I have tried to check up. Whether a mistake of developers it?
With redirect FWC query on WebProxy follow whitout HTTP filter checking. Even in SQL logs field [DestHost] always not resolved ( in IP) when FWC web query redirected 80 -> 8080, but query on 8080 resolved fine.
RE: Clients bypass HTTP filter - 31.Dec.2004 3:54:00 PM
Hey guys,
You can confirm that the ISA firewall does work correctly for both Web Proxy and Firewall clients.
Create a domain name set called CISCO. Then create an entry in that set:
*.cisco.com
Then create an Access Rule that Denies access to that site using all protocols for all users (or a specific users group, it doesn't matter)
Configure the clients as Web Proxy and Firewall clients.
When you go to www.cisco.com the connection is denied.
Now, remove the Web Proxy client configuation, so that the client is a Firewall client only. Go to www.cisco.com
Bingo! The Firewall client is also denied access to the Cisco site.
PROBLEM: The SuftControl app is broken and needs to be updated to fully support the new ISA firewall.
RE: Clients bypass HTTP filter - 1.Jan.2005 7:12:00 PM
BlackPH
Dear Tom, it would be desirable to clear a situation other example.
There is only one rule of access to HTTP protocol (From: Internal , To: External , Users: Internet_HTTP (AD group for web access) ). There is a restriction ( in HTTP filter) on HTTP headers, signatures etc.My ISA server not use SuftControl. -est computer have FWC client installed. When IE configured as web proxy client, HTTP filter workinng fine. But when i use mozilla whitout any configuration , HTTP filter not apply to this query.
How to force apply HTTP filter to redirected inquiries?
Excuse for bad English [Frown]
Happy NY!
[ January 02, 2005, 12:27 AM: Message edited by: BlackPH ]
