Clients still cant FTP with Web Proxy
Clients still cant FTP with Web Proxy - 25.Sep.2004 10:02:00 PM
anihilus
I've read all the posts about FTP, Web Proxy, and ISA 2004...and cannot figure out..
For some reason my clients still cannot FTP with IE or FTP client using the Web Proxy on port 8080.
On the monitor i see: FROM: 192.168.16.10 TO: 207.46.133.140 (microsoft) PORT: 21 PROTOCOL: FTP ACTION: Failed Connection Attempt RULE: Unrestricted Internet access SOURCE NTW:Internal DEST NTW: External
Any ideas?
any help would be great! Thank you!
RE: Clients still cant FTP with Web Proxy - 25.Sep.2004 11:53:00 PM
sysop
hi, i just wanted to let you know that i also experience strange behaviour with ftp sites on the net from my internal network.
Only in my case it only happens with sites that use NAT or some Non routable IP.
RE: Clients still cant FTP with Web Proxy - 26.Sep.2004 5:05:00 AM
nonsence
i get the same problem. i use flashfxp as my client and can never use the http proxy!
RE: Clients still cant FTP with Web Proxy - 26.Sep.2004 5:30:00 PM
sysop
rofl! well i found out what was causing my problems.
DON'T FORGET TO ENABLE 'UPLOAD' IN PROTOCOL FILTERING! (disable read only)
this goes for both inbound and outbound traffic. [ September 26, 2004, 05:32 PM: Message edited by: sysop ]
RE: Clients still cant FTP with Web Proxy - 26.Sep.2004 6:03:00 PM
Hi anihilus,
As sysop said, if you can't upload, make sure the FTP policy allows uploads.
Also, what sites can't you connect to using IE? What are you IE settings for FTP?
Thanks! Tom
RE: Clients still cant FTP with Web Proxy - 26.Sep.2004 9:24:00 PM
anihilus
Great responses....but...
The problem is I cannot connect at all!
CONNECTION -Attempt to connect to ftp.microsoft.com (207.46.133.140) -Using WSFTP, or -IE (Browser Settings: FTP folder view enabled; use passiv FTP enabled)
FIREWALL SETTINGS I have the following settings in the ISA 2004 Firewall Policy: -Unrestricted internet access through the default edge firewall template -allows "all outbound access" from 'Internal to External' -I have FTP "read only" turned off. DO I NEED SOMETHING ELSE? Perhaps another rule?
LOGGING MONITOR RESULTS The log monitor in ISA states "Failed Connection Attempt"
On the log monitor i see: FROM: 192.168.16.10 TO: 207.46.133.140 (microsoft) PORT: 21 PROTOCOL: FTP ACTION: Failed Connection Attempt RULE: Unrestricted Internet access SOURCE NTW:Internal DEST NTW: External
Hope that helps
RE: Clients still cant FTP with Web Proxy - 27.Sep.2004 4:56:00 AM
Hi Sysop,
Can you telnet to TCP 21 at ftp.microsoft.com?
Are you using the SecureNAT or Firewall client?
Thanks! Tom
RE: Clients still cant FTP with Web Proxy - 27.Sep.2004 6:27:00 AM
anihilus
Hi Tom, I assume you were writing to me not sysop
I am using SecureNAT.
My ISA Server 2004 is on Win2003 Server using two NICs, (external connected to a static address; internal at 192.168.16.2)
DHCP is also installed on this machine (is this bad?) assigning (192.168.16.10-255) to clients. All clients use Web Proxy, no clients will use FW Client.
Clients surf with IE, thier browser settings are as follows; everything unchecked except for Proxy which points to 192.168.16.2 using port 8080
EXAMPLE Local Area Connection of a Client:
Physical Address: 00-xx-xx-xx-xx-xx IP Address: 192.168.16.10 Subnet Mask: 255.255.255.0 Default Gateway: 192.168.16.2 DHCP Server: 192.168.16.2 Lease Obtained: 9/26/2004 9:27:15 PM Lease Expires: 9/26/2004 9:28:15 PM DNS Servers: 192.168.16.2, 192.168.16.50 WINS Server: 192.168.16.2
DNS is not installed on this ISA even though the above client points to the isa as a DNS server. (dunno why...i assume its passing through the ISA to the internet)
AD/DNS is instaled on a Exchange 2003 server behind the ISA at 192.168.16.50 (I user ISA to publish the exchange server)
I'm sure there are a million ways to do this but everything works and as far as I know everything is secure. THE ONLY THING NOT WORKING IS FTP FOR MY CLIENTS.
Hope that helps.
thanks. [ September 27, 2004, 06:30 AM: Message edited by: anihilus ]
RE: Clients still cant FTP with Web Proxy - 27.Sep.2004 7:11:00 AM
Hi anihilus,
First, if the ISA firewall isn't a DNS server, make sure the clients DO NOT have it's IP address assigned to them as a DNS server. That is going to break a lot of things.
Test the command line FTP client and see if you can connect to ftp.microsoft.com. But first, telnet to ftp.microsoft.com 21
HTH, Tom
RE: Clients still cant FTP with Web Proxy - 27.Sep.2004 8:36:00 AM
sysop
I cannot test it because my isa server is down atm (i destroyed its NIC to Internet)
By the way my ftp problem is solved.
Thanks! Tom
RE: Clients still cant FTP with Web Proxy - 27.Sep.2004 10:36:00 PM
anihilus
Tom,
I canot FTP via telnet or ftp commandline it just times out.
i changed the DHCP to only point to the Exchange Server at 192.168.16.50 as its DNS
still cannot FTP, just times out. -an
RE: Clients still cant FTP with Web Proxy - 2.Dec.2004 1:46:00 AM
cyskon
What was the solution???????
RE: Clients still cant FTP with Web Proxy - 4.Dec.2004 8:53:00 PM
anihilus
Don't know. No one can give me a straight answer. I've given up.
