Configuration problem ..
Configuration problem .. - 30.Oct.2006 8:40:42 AM
adgroup
hi My scenario is as under. I have ISA 2004 with SP2 on Windows 2003 with SP1. Clients are of mixed environment of windows XP and windows 2003. Network Settings are as under. IP SETTINGS. DSL ROUTER (LAN IP) = 192.168.0.17 DSL ROUter External = 202.147.175.145 DOMAIN CONTROLLER (1ST IP) = 10.1.1.1 DOMAIN CONTROLLER (2ND IP) = 192.168.0.150 DOMAIN CONTROLLER DEFAULT GATEWAY = 192.168.0.17 DNS IP ADDRESS = 10.1.1.1 (LOCAL DNS ADS INTEGRATED ZONE) ALTERNATE DNS = 10.1.1.2 (SAME AS ABOVE) BACKUP DOMAIN CONTROLLER (1ST IP) = 10.1.1.2 BACKUP DOMAIN CONTROLLER (2ND IP) = 192.168.0.151 DEFAULT GATEWAY = 192.168.0.17 DNS IP ADDRESS = 10.1.1.1 (LOCAL DNS ADS INTEGRATED ZONE) ALTERNATE DNS IP ADDRESS = 10.1.1.2 (SAME AS ABOVE). ISA SERVER LAN IP SETTINGS Ip address = 10.1.1.3 Default Gateway = none Primary dns = 10.1.1.1 Alternate Dns = 10.1.1.2 ISA SERVER 2ND NIC IP SETTINGS. Ip address = 192.168.0.16 Default settings = 192.168.0.17 (Ip address of DSL Router) Note* In dns i have enable forwarder to ISP DNS Servers. I just want to know that are the above mentioned settings OK? I don't know why I gave the 2nd ip addresses to PDC and DC, But without this my internet is not working. also If i give the LAN IP of ISA server in the default gate of PDC & BDC then also my internet is not working, So for internet i have added the 2nd IP addresses on PDC & BDC and add the dsl router ip address in the default gateway of PDC and BDC. But now YAHOO MESSENGER is not working for USER ABC Although i have created rule for Yahoo messenger Allow HTTP, HTTPS from internal to external to all user except ABC. Then in the CONFIGURE HTTP i have added the yahoo messenger signature. Then I create a rule to allow HTTP HTTPS from internal to external to ABC. But still not working.. Any Help ADgroup
RE: Configuration problem .. - 30.Oct.2006 10:36:04 AM
edv@aerotec.de
What are the settings for the clients (default gateway, proxy) ? You don't need the second net (192.168.0.X) to be configured at the DCs, otherwise something's totally wrong.....let's see what. Regards, edv
< Message edited by edv@aerotec.de -- 30.Oct.2006 10:42:12 AM >
RE: Configuration problem .. - 30.Oct.2006 12:26:57 PM
JCUEVAS
Hi Do you have ISA server with transparent Proxy or Do you have Proxy Setting in IE. You don't need the secord NIC in your PDC and DC, because you are exposed you network to internet, and this is a Security Risk for you network. I think that you can to use the Proxy Setting in Intenet Explorer (IE). Create OUs in Active Directory and Apply GPO with the Proxy Setting. Never expose you network to internet... Regards,
DCSE, MCSE+Security, CCNA, Security+
RE: Configuration problem .. - 31.Oct.2006 1:34:07 AM
adgroup
hi Thanx for your reply ... Firewall clients are installed on all clients computers.Internet Explorer LAN settings are for configured to use ISA server with por 8080. Ok If i remove 192.168.0.X IP addresses from PDC & BDC, and remove the default gateway addresse (192.168.0.17) Which is the ip address of DSL router then internet browsing stops. If any one guide me the procedure for configuring network for ISA 2004. Scenario is as under. PDC ip = 10.1.1.1 SM = 255.0.0.0 Dns = 10.1.1.1 Alternate Dns = 10.1.1.2 BDC Ip = 10.1.1.2 SM = 255.0.0.0 DNs= 10.1.1.1 ALternate DNS = 10.1.1.2 ISA LAN IP = 10.1.1.3 Sm = 255.0.0.0 DNS = 10.1.1.1 Alternate DNS = 10.1.1.2 ISA 2ND NIC IP ADDRESS IP = 192.168.0.16 SM = 255.255.255.0 DSL Router IP Address IP = 192.168.0.17 SM = 255.255.255.0 DSL router is connected with a Network SWITCH, PDC, BDC, ISA Server is also connected with that Switch. Adgroup
RE: Configuration problem .. - 31.Oct.2006 4:20:47 AM
edv@aerotec.de
Ok, that seem to be the right settings for your nework. Now configure your ISA server as an edge firewall. Any questions on how to do this? Regards, edv
RE: Configuration problem .. - 31.Oct.2006 8:30:18 AM
adgroup
thanx for your response .. In a test environment, I have created a Test PDC and Test ISA Server. But still unable to connect yahoo messenger and Microsoft Outlook. PDC IP address = 10.1.1.5 SM = 255.0.0.0 Default Gateway = NONE DNS = 10.1.1.5 ISA LAN NIC SETTING IP address = 10.1.1.6 SM = 255.0.0.0 Default Gateway = None DNS = 10.1.1.5 2ND NIC SETTING IP address = 192.168.0.14 SM = 255.255.255.0 Default Gateway = 192.168.0.17 Primary DNS = ISP DNS SERVER Altenate DNS = ISP DNS SERVER. Note* Now I donot add the forwarder on the PDC (DNS SERVER), Because internet is not working if I do that, Thats why I add the ISP DNS SERVER in the 2nd NIC.Now Internet is working. In the ISA 2004, I create EDGE FIREWALL settings, Internet is working fine but Yahoo messenger is not working. Then I Allow all protocol from internal to external to all users, But still yahoo messenger is not working. Waiting for urgent help ..... Adgroup
RE: Configuration problem .. - 1.Nov.2006 6:24:03 AM
edv@aerotec.de
I'm not familiar with yahoo messenger, but the first idea i'd have is to check Windows XP firewall settings and make sure that no incoming traffic is blocked. Have you checked using the monitoring tab in ISA? Besides: it's no problem to add the ISPs DNS server to the external nic of ISA, but usually it's the router who should deliver this adresses to the ISAs nic........in my scenario, i have configured the router to act as DHCP server and setup a reservation for the MAC address of ISAs external nic. Then configure the external nic to use dhcp for both, IP address and name servers. This way the router allways serves the same IP for the external nix and delivers the IPs of the DNS servers.
