Configuring ISA 2004 On SBS 2003 With Two NICs? Please Help
Configuring ISA 2004 On SBS 2003 With Two NICs? Please ... - 7.Jul.2006 12:55:19 PM
habibalby
Configuring ISA 2004 On SBS 2003 With Two NICs? Please Help -------------------------------------------------------------------------------- Hi All, Due to the limitation of the Internet Bandwidth through our ISP, I'm planning to make an SBS 2003 to server our needs to utilize the internet bandwidth and other featuers. I have SBS 2003 configured as: 1. Directory Services 2. DNS 3. DHCP 4. Exchange 5. Now trying to put the ISA 2004 to be as a deafault Gateway, Proxy Server and Firewall. LAN Setup: Is this right setup to be able to the users to get Internet Access? Also, for the ISA, what is the template Network that i have to choose for this design? What I know for the rules that should be available in the Firewall Access rules are as follows: DHCP Rules: 1.Allow DHCP Request --- From Internal to LocalHost 2.Allow DHCP Reply --- From LocalHost to Internal DNS Rules: 1. Allow DNS From Internal to LocalHost 2. Allow DNS from LocalHost to Internal Internt Access: 1.Allow HTTP from Internal to External 2.Allow HTTPS from Internal to External 3.Allow FTP from Internal to External DHCP Scope Options: Start IP Address from 192.168.1.3 To 192.168.1.15 003 Router: 192.168.5.1 006 DNS Server: 192.168.1.1 015 DNS Domain Name: habibalby.com Please, I need your reply on this design to be able to implement it. Thanks, Habibalby
< Message edited by habibalby -- 7.Jul.2006 1:15:03 PM >
For online help with ISA Server 2004 & 2006 SE or EE. Please call on +973-39228431
RE: Configuring ISA 2004 On SBS 2003 With Two NICs? Ple... - 11.Jul.2006 3:02:37 AM
Bif
I've got pretty much the same setup using a cable modem instead of the ADSL. I would highly suggest you read through all five of Tom Shindler's Trek through SBS2003 install. He never did the part six but the first five are great. They will get you up and going pretty quickly. Here's the link to the first article. The links to the other's are in the article. http://www.isaserver.org/articles/200sbsinstallpart1.html
RE: Configuring ISA 2004 On SBS 2003 With Two NICs? Ple... - 11.Jul.2006 3:43:32 AM
ababinchak
See my reply to your other post. SBS is a very complicated product. Much thought and configuration has gone into creating the wizards to install it. You need to use them to acheive bliss among all of the server products running on the same box.
Amy Need more help? http://isainsbs.blogspot.com
RE: Configuring ISA 2004 On SBS 2003 With Two NICs? Ple... - 20.Jul.2006 8:01:58 AM
habibalby
HI Once again, I eventually relized that i wouldn't treat the SBS 2003 as a normal Server or DC. After getting the orginal 6 CDs from a friend of mine and installed it it works fine without it any problem in joing clients to domain by: 1. Adding the user, then automatically adding the computer name. 2. Going to clinet machine and access http://servername/connectcomputer it connects fine and the client joined into the SBS 2003 successfuly. However, after installing ISA 2004 as a Edge Network using two NIC one from External and the other for internal, clients can access the internet using the Default Gateway as the Internal IP of the SBS 2003. But I cannot access http://servername/connectcomputer to be able to connect the new client to SBS 2003 and also clients cannot get access to SBS 2003 Server to gain resources. Moreover, when i try to access http://servername.domanname.com:80 it open successuly but i cannot click on Connect to Network. And I got an error message says that the IIS is Denied Access to this IP. What are the defualt rules that must be in used ISA 2004 with SBS in order for SBS 2003 to function all the Services that SBS 2003 provides? like DNS, DHCP, ect. Thanks, Habibalby
RE: Configuring ISA 2004 On SBS 2003 With Two NICs? Ple... - 24.Jul.2006 11:58:03 PM
ababinchak
There are 28 system policies and 21 Firewall policies that make the SBS magic happen. Run the Connect to the Internet Wizard and it will set them up from you. You can tweak from there but you really need to start from the default base of policies.
RE: Configuring ISA 2004 On SBS 2003 With Two NICs? Ple... - 28.Jul.2006 9:49:06 AM
habibalby
hi guys, now I solved the problem by using the ISA 2004 on SBS 2003 as a Proxy and Cache Server. Configured Auto Discovery for Firewall Client and in DHCP and the problem has been sloved. By the Firewall Client, I can access both the Internal Network as well as the Internet. Thanks guy for your great help. Habibalby
RE: Configuring ISA 2004 On SBS 2003 With Two NICs? Ple... - 11.Aug.2006 10:05:31 AM
sam_hunter
Do all of you guys realize that there's a wizard in that SBS box called the "Connect to Internet and Email wizard" that does all this for you? All of the needed rules for basic connectivity, email, etc.. are set up by that wizard. And do you know about Remote Web workplace? Listen to the podcasts on this website: http://blogs.technet.com/sbs
RE: Configuring ISA 2004 On SBS 2003 With Two NICs? Ple... - 12.Aug.2006 10:03:11 AM
habibalby
HI sam_hunter, First of all I'd like to thank you for your reply, but I want to clearify the Connect to Internet and Email Wizard. Since my setup is clearly mentioned in the diagram below which one should I select: 1. A Local Router Device with an IP Address. 2. A Direcrt Broadband Connection. To which one of these should I run? BTW, I'm using ADSL Router with Dynamic IP. Thanks, Habibalby
RE: Configuring ISA 2004 On SBS 2003 With Two NICs? Ple... - 15.Aug.2006 9:15:05 AM
sam_hunter
One of the problems I see is that you have a dynamic IP and the CEICW and ISA won't deal well with a dynamic IP. (this is not a limitation of ISA, but rather SBS's wizard). Place a router between you and that dynamic IP and then use the setting for "direct broadband" and enter in the static IP of an address near the router IP and the static IP address for an internal address scheme.
RE: Configuring ISA 2004 On SBS 2003 With Two NICs? Ple... - 18.Aug.2006 8:58:49 PM
habibalby
HI sam_hunter, Thanx for replying me. can you draw a diagram for this setup please? Thanx Habibalby
