Connection with DC & Exchange 2007
All Forums >> [ISA 2006 General] >> General >> Connection with DC & Exchange 2007 Page: [1]
Connection with DC & Exchange 2007 - 6.Sep.2008 3:04:19 PM
create_share
I am getting the following errors and then my domain users cannot connect to ISA Server 2006 and Exchange Server 2007 published on isa. I can login to isa server using only local administrator account but not domain administrator account.
I have to restart my isa server to make it work with domain.
1.
Event Type: Error
Event Source: NETLOGON
Event Category: None
Event ID: 5783
Date:  9/6/2008
Time:  2:24:07 PM
User:  N/A
Computer: ISASERVER01
Description:
The session setup to the Windows NT or Windows 2000 Domain Controller \\isaserver01 the domain domain.com is not responsive.  The current RPC call from Netlogon on \\isaserver01 to \\isaserver01.domain.com has been cancelled.
2.
Event Type: Error
Event ID: 5719
Date:  9/6/2008
Time:  1:47:50 PM
User:  N/A
Computer: isaserver01
Description:
This computer was not able to set up a secure session with a domain controller in domain DOMAIN due to the following:
There are currently no logon servers available to service the logon request.
This may lead to authentication problems. Make sure that this computer is connected to the network. If the problem persists, please contact your domain administrator.
ADDITIONAL INFO
If this computer is a domain controller for the specified domain, it sets up the secure session to the primary domain controller emulator in the specified domain. Otherwise, this computer sets up the secure session to any domain controller in the specified domain.
3.
Event Type: Error
Event Source: Microsoft ISA Server Web Proxy
Event ID: 14200
Date:  9/6/2008
Time:  1:46:17 PM
User:  N/A
Computer: EXCHANGESERVER01
Description:
ISA Server was unable to establish an SSL connection with 192.168.1.4. A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
RE: Connection with DC & Exchange 2007 - 8.Sep.2008 2:28:44 AM
bati
Found this and good luck:
We had a strange problem with our Windows 2003 SP2 servers not accepting network credentials or throwing RPC errors. These errors seemed to come out of nowhere. The only way to temporarily fix the problem was to login with a local account and reboot the servers. After the reboot everything was fine. The problem only affected about 10 to 15 of our servers and there seemed to be no commonality as to which ones were affected and which ones were not. But the problem was steadily getting worse.
I opened a call with Microsoft and they had two suggestions:
1 - Make sure that your NICs do not have any power settings that might be causing them to go to sleep. Check for a Power option in Device Manager and turn it off or change it to don’t go to sleep.
2 -
Network related problems after installing Windows 2003 SP2.
Our servers didn't have power settings for the NICs. Microsoft told us to use these settings to eliminate the problem. So we are pushing out the following registry entries to all 200+ servers to fix the problem.
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters]
"EnableRSS"=dword:00000000
"EnableTCPA"=dword:00000000
"EnableTCPChimney"=dword:00000000
"DisableTaskOffload"=dword:00000001
So far it has been about a week and the problem has not reoccurred on any server that has been patched. We have over 100 servers patched so far.
There's an article from Microsoft - http://support.microsoft.com/kb/938449
(in reply to create_share)
RE: Connection with DC & Exchange 2007 - 8.Sep.2008 8:16:07 AM
Ah yes, the dreaded SP2 RSS bug.
(in reply to bati)
RE: Connection with DC & Exchange 2007 - 9.Sep.2008 7:52:46 PM
create_share
I did RSS settings when i installed Windows 2003 SP2 and that was more than 1 year ago. I don't think this is because of RSS now. Should i disjoin and rejoin ISA Server to domain?
RE: Connection with DC & Exchange 2007 - 9.Sep.2008 10:12:04 PM
bati
Worth trying, back up the ISA config and stop ISA services, eg the Microsoft Firewall etc, let us know how you go.
