Create more than one Listener to an IP
All Forums >> [ISA Server 2004 General ] >> ISA 2004 SBS >> Create more than one Listener to an IP Page: [1]
Create more than one Listener to an IP - 9.Jun.2006 9:29:25 PM
zytech
Hi,  I have a SBS2003 Premium.   I am trying to publish two differents sites, with its respective SSL Certificate. ( ie  mail.domain.com  and store.domain.com ).
When I try to create the listener the system does not let me use both because they overlap each other.  The problem is that I cannot add another IP to MY external Adapter, because my Broadband router only do Port Foward to a single IP.  Both sites have to be publish at port 80 for http and 443 for https.
Any help is very appreciated.
RE: Create more than one Listener to an IP - 21.Jun.2006 7:50:59 PM
ababinchak
I'm no IIS expert but I beleive that you are going to need that second IP address. The only way around it I know is to change the way your sites are published so that they read. www.you.com/mail and www.you.com/store
Amy
Need more help? http://isainsbs.blogspot.com
(in reply to zytech)
RE: Create more than one Listener to an IP - 21.Jun.2006 8:53:29 PM
tonygauderman
I never do this because I don't need to, and you probably shouldn't unless you absolutely have to, but I believe that in IIS you can publish multiple sites to the same IP Address and IIS will choose the site based on the host header.
When you publish the server in ISA, you can use a wildcard cert if all the sites are in the same DNS domain (i.e. *.internetsite.com).  If they are not in the same domain, I think you are out of luck.
(in reply to ababinchak)
RE: Create more than one Listener to an IP - 26.Jun.2006 4:51:12 AM
ababinchak
Sounds like Tony and I agree. In the example I gave the /mail and /store would be handled by host header.
Amy
(in reply to tonygauderman)
