DHCP Problem after Installation of Firewall Client
All Forums >> [ISA 2006 Firewall] >> Firewall Client >> DHCP Problem after Installation of Firewall Client Page: [1]
DHCP Problem after Installation of Firewall Client - 5.Dec.2007 3:31:31 AM
Tafkadasoh
I've got a Isa Server 2006 installed (with activated Proxy), a Windows SBS 2003 R2 as Domain Controller, and the Clients are running on Windows XP SP2 and are member of the domain.
When I install the Firewall Client on a Client computer, the computer looses the network connectivity. Usually it get's an IP-adress from the 192.168.62.xxx net, but after installation of the Firewall Client the DHCP fails, and the client gets a 169.254.xxx.xxx adress and the network symbol in the tray says "Limited or no Connectivity"
If I deinstall the Firewall Client, the Computer immediately get's a correct ip-adress from the .62 subnet.
Has anybody an idea, what's the problem? Thanks in advance!
Surprisingly enough, I had no problems with the firewall client on my laptop, which is also in the .62 net, but not a member of the domain.
RE: DHCP Problem after Installation of Firewall Client - 11.Dec.2007 4:32:49 PM
Tafkadasoh
Has really noone just any idea or ideas for failure analysis? This would be great, thanks in advance.
(in reply to Tafkadasoh)
RE: DHCP Problem after Installation of Firewall Client - 14.Dec.2007 11:09:27 AM
Yah, I have never heard of such an issue with the Firewall Client.
Is this on all your clients ?
RE: DHCP Problem after Installation of Firewall Client - 17.Dec.2007 7:38:14 AM
Tafkadasoh
Yeah, unfortunately. I tested it on several (not all) clients which are member of the domain, and on each I got the same error. Just on one machine outside the domain, it worked well. Till now I had no chance to test it on another computer outside the domain, regrettably.
(in reply to elmajdal)
RE: DHCP Problem after Installation of Firewall Client - 9.Jan.2008 7:46:18 AM
Tafkadasoh
Today I tested the FW-Client installation again on a fresh installed XP SP2 machine. The machine joined the domain, and suprisingly the Firewall client worked well though.
But when I finally installed the anti virus software "Avira Antivir Workstation", the firewall client wasn't been able to connect to the isa server anymore.
How can that be?
RE: DHCP Problem after Installation of Firewall Client - 9.Jan.2008 10:07:16 AM
mmm, i have seen this with Nod32 Antivirus as well.
there is for sure an option in the antivirus that will consider Firewall Client a safe application. There is such option in Nod32 and that was the way to unblock Firewall Client.
Tarek
RE: DHCP Problem after Installation of Firewall Client - 14.Jan.2008 5:39:16 AM
Tafkadasoh
Hmmm.... I searched for such an option, but I just found two possibilities which each didn't resolve the problem:
1) I configured the Antivir Guard program (which runs as a process in the background to search for viruses in running programs, when accessing files etc.) so, that the FwcAgent.exe and FwcMgmt.exe are entered under "process exceptions"
2) I deactivated all options at the "extended danger categories", like blocking spyware, adaware, backdoor programs, etc.
I couldn't find other options such as a list of blocked processes/programs, where I could unblock the FWC.
I also configured the FwcAgent.exe as an exception in the Windows Firewall, without success.
Do you know more details, for what configuration options I should look in my Antivir?
Another thing: Again I get problems with the net as long as the FWC is installed (just as described in the first post.) When the FWC is installed and I try to get a new IP via "ipconfig /renew" then I get the following (german) error message:
"Beim Aktualisieren der Schnittstelle "LAN-Verbindung" ist folgender Fehler aufgetreten: Ein Vorgang bezog sich auf ein Objekt, das kein Socket ist."
translated it means
"The following error occured when refreshing the interface "LAN-Connection": An operation refered to an object, which is not a socket."
Anyone a clue?
Thanks in advance,
Martin
< Message edited by Tafkadasoh -- 14.Jan.2008 5:46:52 AM >
