DMZ - LAN communication problem....
All Forums >> [ISA Server 2004 Firewall] >> DMZ >> DMZ - LAN communication problem.... Page: [1]
DMZ - LAN communication problem.... - 19.May2005 3:09:00 PM
wlandymore
I have the following setup -
Internet NIC:
IP: 24.222.1.1
MASK: 255.255.255.240
GATEWAY: 24.222.1.14
DNS: NONE
Internal NIC: (PART OF THE DOMAIN)
IP: 192.168.1.1
MASK: 255.255.255.0
GATEWAY: NONE
DNS: 192.168.1.12
DMZ NIC:
IP: 172.16.0.1
MASK: 255.255.0.0
GATEWAY: NONE
DNS: NONE
I then plugged a wireless router into the DMZ card to see if I could setup a wireless network on it.
The router's info is:
IP: 172.16.0.2
Local IP: 172.16.1.1
(I was using 172.16.0.1 for client DNS)
I setup the network rules for DMZ<>LAN and DMZ > WAN. I also have temp. acces rules allowing DNS use from the DMZ>LAN and 'all access' from DMZ<>LAN. If I plug into the router and use the proxy:
172.16.0.1 I can get the internet.
The only thing that I can't get is the comunication from the the DMZ to the LAN and the other way around. I setup those 'all access' rules for testing and that won't even work.
Does anyone know what I might be missing here?
[ May 19, 2005, 03:13 PM: Message edited by: wlandymore ]
RE: DMZ - LAN communication problem.... - 23.May2005 10:37:00 AM
Hi W,
If you want to create a wireless DMZ, you want a WAP, not a wireless NAT device.
Is that what you're trying to accomplish? Check out the articles I did on creating a wireless DMZ for details.
(in reply to wlandymore)
