DMZ Design
All Forums >> [ISA Server 2004 Firewall] >> DMZ >> DMZ Design Page: [1]
DMZ Design - 11.Apr.2006 3:48:45 PM
bhavin78
I am planning to put exchange and web server on DMZ network. Question is what ip address do I use? Righ now its inside the internal network and it's using internal ip address which is routable on internet. 1:1 static route is setup on cisco router and checkpoint firewall.
Need help on this for both web and exchange server
RE: DMZ Design - 13.Apr.2006 6:09:45 PM
jchiver
Question why do you want to put your exchange server in the DMZ???
please explain what it is you are trying to accomplish.
Jeremy
(in reply to bhavin78)
RE: DMZ Design - 13.Apr.2006 6:13:15 PM
bhavin78
I am very new to this and so far what I have read and research it says that it's good to put any server which is accessed directly from internet or need direct internet connection in DMZ. I might be wrong , help me out to make better understanding of DMZ and option for my exchange server and webserver.
(in reply to jchiver)
RE: DMZ Design - 13.Apr.2006 6:20:19 PM
jchiver
you are correct in what you have read.
Servers such as Web servers and FTP servers should be kept in the DMZ but exchange is different.
because exchange is heavily intergrated with your domain having this in your DMZ would open up big holes in your domains security.
If you are looking at using an ISA server then you can only allow port 25 traffic to it which will mean it can recieve email from the internet and port 443 so you can enable outlook web access for your users.
There are loads of guides on this Site many written by a chap called Tom Shnider who you will see alot on these forums.
RE: DMZ Design - 13.Apr.2006 6:27:33 PM
bhavin78
so how will AD talk with exchange if I put it in DMZ?
What's the best practise and how?
what about webserver, which will be accessed by internet and internal user?
RE: DMZ Design - 13.Apr.2006 6:30:41 PM
bhavin78
why will Exchange be secure in internal network when compare to DMZ?
RE: DMZ Design - 13.Apr.2006 7:32:33 PM
bhavin78
I read few articles and they talk about Front-End/Back End exchange server. IN my case I only have one server for a small company with 100 users. Can I get some help on this and my very first question.
RE: DMZ Design - 13.Apr.2006 7:48:32 PM
Hey guys,
For the best and most secure design for a FE/BE Exchange Deployment, check out:
http://www.isaserver.org/tutorials/Creating-Multiple-Security-Perimeters-Multihomed-ISA-Firewall-Part1.html
RE: DMZ Design - 13.Apr.2006 7:52:37 PM
bhavin78
I read that article before but, I am confused as I am not going with FE/BE server. I just have one exchange server for a very small company with 100 users and they cannot afford to buy extra license for exchange server.
so please help me out other way.
RE: DMZ Design - 22.May2006 6:31:31 PM
bhavin78
Tom,
I will appreciate if you can help me figure out the question I have on DMZ?
I  want to install Exchange securely  but dont want to spend extra money using FE Exchange server in DMZ as it's a 100 user company with two location. In this case can I cannot put exchange on DMZ as it's intergrated with AD and it needs to talk with AD and which opens security hole, what are my other options which are secure?
Same question on DMZ with other servers (Terminal server, WebServer etc whey they go DMZ or Internal network).
They will be accessed from out side but somehow they need to talk with AD for authentication and data stored on SQL Server and File Server. So, some how there needs to be a connection with internal server from DMZ. If this is the case than you cannot put any server on DMZ which are member of Domain.
I am very confused as I am very new to security so, please help me out.
RE: DMZ Design - 22.May2006 8:44:50 PM
 check my answer in ur other thread:
http://forums.isaserver.org/Confused_with_DMZ/m_2002017224/tm.htm
