DMZ Help
All Forums >> [ISA Server 2004 Firewall] >> DMZ >> DMZ Help Page: [1]
DMZ Help - 16.Jan.2007 12:35:01 PM
dnguyen2205
I just recently tried to put our Web server behind ISA 2k4 w/ sp2 on the DMZ. On our webserver we run two websites on it. One works and the other does not. This is how I have it set up:
Webserver:
- Set the NIC with DMZ address's for both websites
- Set the correct DMZ IP's for both websites in IIS
ISA Server:
- I added the two external IP's for our website to the External NIC
- Created two web listeners for both websites
- Created two web publishing rules
     -Forward www.abc.com to DMZ IP address (192.168.1.XX)
     -Forward www.123.com to DMZ IP address(192.168.1.XX)
- So website www.abc.com works, but www.123.com does not.
        - If I swapped the DMZ address's in the publishing rules, then www.123.com works, but www.abc.com does not.
Can someone help me out? If you need any more information, let me know!
Thanks!!
< Message edited by dnguyen2205 -- 17.Jan.2007 3:28:54 PM >
RE: DMZ Help - 16.Jan.2007 5:13:21 PM
mrupright
Hi dnguyen2205,
You bound two extra public IP's to your ISA external interface so you now have three (3) external ips?  On your web listeners properties click the network tab.  Did you define the public ip addresses here?  Click your External adapter and then click the Addresses button.
Under Available IP Addresses, you should see the ip's you bound to the wan interface.  Click the "Specified IP Addresses on the ISA Server computer in the selected network"  Choose your public IP and click "Add" then "OK"  Then "apply" and "ok" again.  Do the same for the other web listener.
Happy to help
Mark
< Message edited by mrupright -- 16.Jan.2007 5:33:11 PM >
(in reply to dnguyen2205)
RE: DMZ Help - 16.Jan.2007 5:24:27 PM
dnguyen2205
Hello mrupright:
- Yes
On your web listeners properties click the network tab.  Did you define the public ip addresses here?  Click your External adapter and then click the Addresses button. Under Available IP Addresses, you should see the ip's you bound to the wan interface.  Click the "Specified IP Addresses on the ISA Server computer in the selected network"  Choose your public IP and click "Add" then "OK"  Then "apply" and "ok" again.  Do the same for the other web listener.
- Yes I defined the public IP's for both of our websites on the weblistener. Then for the "TO:" portion I directed it to the DMZ I created on the Webserver, to both websites.
Thanks for your help!
Dave
< Message edited by dnguyen2205 -- 16.Jan.2007 5:26:19 PM >
(in reply to mrupright)
RE: DMZ Help - 18.Jan.2007 3:34:42 PM
dnguyen2205
Anyone!??
RE: DMZ Help - 18.Jan.2007 11:31:12 PM
mrupright
Hi dnguyen2205,
Do you mean for each web server publish rule you directed it to the corresponding websites dmz ip address in the TO tab?  You bound a second ip to your webserver and configured the websites to listen on the different ip's:  www.abc.com - 192.168.1.1 and www.123.com - 192.168.1.2 and that is what is in the TO tab?
HTH
Mark
< Message edited by mrupright -- 18.Jan.2007 11:42:44 PM >
RE: DMZ Help - 19.Jan.2007 12:18:56 AM
dnguyen2205
ORIGINAL: mrupright
Hi dnguyen2205,
HTH
Mark
Hello Mark,
Yes, that is how I configured everything. Do you see anything wrong with the way I configured it, that could cause my issue?
Thanks for the reply.
< Message edited by dnguyen2205 -- 19.Jan.2007 12:21:58 AM >
RE: DMZ Help - 19.Jan.2007 1:18:31 PM
mrupright
Hi dnguyen2205,
Grrrr...
I have tried to duplicate the problem in my vmware lab to no avail.  I came close a few times but after a flush of dns cache....poof it works.  Have you tried flushing the dns cache on ISA and your webserver?  I should be able to duplicate the issue you are having...but then again...my lab setup can still be different from your production setup.
HTH
Mark
RE: DMZ Help - 19.Jan.2007 1:24:09 PM
dnguyen2205
Hi Mark,
No, I haven't tried the DNS flush yet, I will try it this weekend to see what happens.
Dave
