DMZ Setup Issues
DMZ Setup Issues - 28.Sep.2006 2:52:33 AM
jckelley
I am trying to setup a tri-homed DMZ with public IPs on the DMZ segment, I have a public 16 address IP space that I have partitioned into 2 parts. The setup I have tried to use is... Router: IP:72.216.252.142 MK: 255.255.255.240 Routes: 72.216.252.128/255.255.255.248,72.216.252.141 72.216.252.136/255.255.255.248,72.216.252.142 ISA Server: (ISA not yet installed, trying to get the routing to work right first) Public IF: IP: 72.216.252.141 GW: 72.216.252.142 MK: 255.255.255.248 DMZ IF: IP: 72.216.252.134 GW: <NULL> MK: 255.255.255.248 MailServer: MailServer IF: IP: 72.216.252.132 GW: 72.216.252.134 MK: 255.255.255.248 Now I can ping from the Internet to the ISA DMZ nic, but no further. On the mailserver I can ping to the ISA Public IF but no further. So i know that i am missing a critical step on the ISA server routing (routing table?) but i do not know what it is. Any assistance would be greatly appreciated.
RE: DMZ Setup Issues - 29.Sep.2006 3:47:53 AM
jckelley
There are 2 points where routing is occuring, i think, which is on the router and the (future) isa server. From the internet I can ping the DMZ card so i feel comfortable that the router is routing correctly. I just cant ping past the DMZ card. As for the other direction i can ping from the DMZ to the Public Card but i can not ping past it (wether it be the router or the internet itself). Am i missing something? I have been racking my brain on this for about a week now. These are the routes currently setup on the router... Routes: 72.216.252.128/255.255.255.248,72.216.252.141 72.216.252.136/255.255.255.248,72.216.252.142 Are these right? Or is their a route that i am missing? Thank you for the help. JCK
RE: DMZ Setup Issues - 12.Dec.2006 7:40:03 PM
mcox
My friend, check the ISA documentation properly. I think pinging is turned off by default. Also, check the system policies too. Thanks MC.
RE: DMZ Setup Issues - 13.Dec.2006 12:05:12 PM
jckelley
ISA Server is not yet installed. I am trying to get the tri-homed working first and then install ISA server. The thought being that with one less factor to fight it may make the process easier. So far though it has been far from. At this point I am looking at doing a dual firewall configuration with ISA as my inside firewall and a Cisco ASA for the outside firewall. But if you have suggestions, I am all ears. Thank You for the Help. JCKelley
