DMZ and Sharepoint
All Forums >> [ISA Server 2004 Firewall] >> DMZ >> DMZ and Sharepoint Page: [1]
DMZ and Sharepoint - 6.May2004 12:53:00 PM
MACRO33
Hi All,
Got a new client with a web server and a sharepoint extranet. Have an existing Sonic wall doing VPN and routing to these two web servers but would like to protect the private network a little better. Thought of putting the Sharepoint and Web server on a DMZ between the sonicwall and an have an ISA Server protecting internal domain
sonic---
l l
l Web/Sharepoint
l
l
ISA
l
Private domain
Question: is this a good setup as the sharepoint has to be updated regularly and is it fairly simple to configure as I have limited experience with type of scenario
Thanks in advance
Paul
RE: DMZ and Sharepoint - 7.May2004 11:54:00 AM
Hi Paul,
It'll work, but the level or protection the sonicwall can provide is pretty small. What type of access to you need to your SharePoint site? Have you tried publishing your SharePoint site yet by placing it behind the ISA Server?
(in reply to MACRO33)
RE: DMZ and Sharepoint - 7.May2004 2:55:00 PM
MACRO33
ISA not purchased yet as we are doing a pitch for this client.( Their Budget a bit limited I am afraid). The sonic wall is the existing firewall and routing through to the web server Extranet and domain.
The extranet is required by staff where the website is well, a website.
The sonicwall hosts VPN between two city sites and I thought the ISA would be good for the internal domain protection.
Are you suggesting that a DMZ would be more trouble than its worth in this scenario?
Paul
RE: DMZ and Sharepoint - 9.May2004 5:48:00 PM
Hi Paul,
The DMZ would actually be easy. The issue is security. What does the sonicwall bring to the table in terms of security? If its just packet filtering, then the site should really be behind the ISA firewall, because the sonicwall isn't doing any protecting other than a packet filtering router (like a pix).
RE: DMZ and Sharepoint - 14.May2004 1:44:00 PM
MACRO33
Thanks Tom,
Will need to study up a bit(what's new) to get all working behind ISA.
RE: DMZ and Sharepoint - 16.May2004 6:16:00 PM
Hi Paul,
No problem. Post when you have questions on the new features.
RE: DMZ and Sharepoint - 29.May2004 10:44:00 PM
twscottIII
Tom,
If you need to enable users external to your company access to this sharepoint site would you not want to set the sharepoint server up in its own domain inside the DMZ?
RE: DMZ and Sharepoint - 30.May2004 2:43:00 AM
Yes, if this is purely an extranet site and you don't need access to domain accounts.
RE: DMZ and Sharepoint - 2.Jun.2004 7:57:00 PM
twscottIII
What if you need both external users and internal domain users to access the site? Is there a way to do that without adding the external users to your internal Active Directory? Or is that the only way to support both?
RE: DMZ and Sharepoint - 3.Jun.2004 2:40:00 AM
If the site isn't on a domain controller, you can create user accounts in the local SAM of that machine.
RE: DMZ and Sharepoint - 3.Jun.2004 3:45:00 AM
twscottIII
Tom,
I appreciate all of the good information. Would this solution, putting users in the local SAM, scale well?
RE: DMZ and Sharepoint - 3.Jun.2004 2:51:00 PM
Unfortunately no. But how many machines are you talking about? If you need a good scaling solution, you can always create a domain in the DMZ, and then create a one-way trust so that the DMZ domain trusts the Internal network domain, but not the other way around.
RE: DMZ and Sharepoint - 4.Jun.2004 3:02:00 PM
twscottIII
Ok now we are gettting somewhere!
This is what I wanted you to tell me. The two domains and a one way trust is how I have this setup right now. For the most part it is working really well. Users from both domains are able to log into the sharepoint sites and the major benefit is that you can import both internal and external users into the profile database (you cannot import the local SAM users into the profile database). The major problem that I am having now is that the webserver sits in the domain (dmz.local) inside the dmz and when a user from the lan domain (company.com) hits the sharepoint machine it will not grab there windows logon information through integrated authentication. I am sure that this is because the server and the user are in different domains. Is there a way to tell the server to attempt integrated authentication for users from domains other than the one that the webserver sits in?
I hope this is clear but if you need more information please let me know.
[ June 04, 2004, 05:19 PM: Message edited by: Tom Scott ]
RE: DMZ and Sharepoint - 5.Jun.2004 12:00:00 AM
Have you created the trust between the domains?
If so, then there should be no problem using integrated authentication, unless there is some peculiarity with Sharepoint that I'm not aware of.
Are you using SSL on the sites? If so, just force basic auth and SSL and forget Integrated auth.
Are the remote users using integrated or basic?
Do you see any domain communication errors in the Event logs?
