DMZ fails after ip range changed
All Forums >> [ISA Server 2000 Firewall] >> DMZ >> DMZ fails after ip range changed Page: [1]
DMZ fails after ip range changed - 9.Dec.2005 6:10:44 PM
evoroel
Hi
We are using ISA Server 2000 with a trihomed DMZ for over 4 years now and it has worked fine until now. Today we moved from a Leased Line to SDSL. The SDSL was tested with a desktop PC and works fine.
The only thing that has changed is the IP range for the Red interface and Orange (DMZ) interface.
I have changed all the IP addresses according to the setup.
Many things work fine, like internet access from the ISA server and the internal network.
But I can't get a connection (DNS, ping, www, nothing) from the DMZ to the internet.
I have adjusted all the old rules and checked and rechecked all the settings. It keeps failing.
I can ping the isa server's DMZ ip address from the servers located in the DMZ zone, but not the external IP address. That's maybe the first issue to resolve.
Is there an issue with ISA 2000 when the ipadresses are changed? I allready have restarted the server.
RE: DMZ fails after ip range changed - 22.Aug.2006 5:10:33 AM
skhan22
Hi evoroel. I just saw your post as I was trying to find some help on DMZ under ISA 2000. I have setup the dmz  according to the examples found on this website, but i am unable to ping any external source from the DMZ. I don't if you got your issue resolved.
NIC 1 External:
IP: 66.139.XX.77
SM: 255.255.255.252
GW: 66.139.XX.78
NIC 2 Internal:
IP: 192.168.0.1
SM: 255.255.255.0
NIC 3 DMZ:
IP: 66.139.XX.73
SM: 255.255.255.252
DMZ Web Server NIC:
IP: 66.139.XX.74
SM: 255.255.255.252
GW: 66.139.XX.73
Packet Filter and Routing is enabled. I have also created a packet filter from outgoing tcp port 80 traffic.
(in reply to evoroel)
