DNS Problem
All Forums >> [ISA Server 2004 Cache] >> General >> DNS Problem Page: [1]
DNS Problem - 5.Jan.2007 8:56:57 AM
asadsq
Hello,
I have installed Windows 2003 R2 Server (licensed) &  MS ISA Server 2004. I confgure ISA perfectly but  i am getting DNS error in browser. I have configured DNS twice but error remains same.
I am using ACER Altos G320 machine as a server. Machine have two NIC's one is connected with LAN & other one is configure with real IP.
Could you please help me.
Thanks in advance,
Asad Siddiqui
RE: DNS Problem - 5.Jan.2007 9:10:08 AM
make sure you do not put your ISP DNS on your ISA External NIC !!!
read this : http://www.isaserver.org/tutorials/Configuring_ISA_Server_Interface_Settings.html
Windows Expert - IT Pro MVP
(in reply to asadsq)
RE: DNS Problem - 5.Jan.2007 9:26:12 AM
asadsq
Thank you very much for your valuable suggestion.
Let me try this sol, then i will let you know if i have some problems
(in reply to elmajdal)
RE: DNS Problem - 5.Jan.2007 12:09:00 PM
Hey asadsq,
you are wlecome,
waiting for your reply.
RE: DNS Problem - 5.Jan.2007 5:47:58 PM
Hi Asad,
you might also post the result of the command "ipconfig /all" on ISA *unmodified*.
RE: DNS Problem - 9.Jan.2007 8:54:36 AM
asadsq
Hello,
I followed the procedure mention in the web site but still i am getting DNS error in browser. I can ping my real IP provided by ISP also i can ping their gateway but i am not able to ping their mentioned DNS(s).
Could you now tell me that what should i do now?
Regards
Asad Siddiqui
RE: DNS Problem - 9.Jan.2007 10:23:46 AM
whats the browser error ??
have u configure a forwarder  ? http://www.petri.co.il/configure_dns_forwarding.htm
can you answer stefaan question
RE: DNS Problem - 10.Jan.2007 10:21:33 PM
asadsq
Browser is giving me "Server or DNS Error",  i configured forwarders & i also tried without forwarders.
When i ipconfig it shows me the following result
Host name .....................................................: Server
Primary DNS Suffix...........................................: nipa.edu
Node Type ......................................................: Unknown
IP routing enabled ............................................ No
WINS Proxy Enabled ......................................... No
Dns Suffix Search List ....................................... nipa.edu
As i have two NIC's one shows Real IP assigned by ISP & on this NIC NetBIOS over TCP/IP is disable also DHCP disabled. On other NIC which is LAN configured 192.168.0.1 with DNS IP : 192.168.0.1.
I can ping ISP's real Ip & their gateway but i can't ping their DNS. When contacted, they said that it is problem on your end.
So could you please help me in this issue? I am sick of this i tried many options but all in vain.
At last i have no option to switch back to Win 2K Server & ISA 2K.
Please sort this problem for me.
Regards
Asad
RE: DNS Problem - 11.Jan.2007 4:17:09 PM
Hi Asad,
what's your definition for the word *unmodified*?
Where is your DNS server installed? On the ISA server itself or on an internal server?
RE: DNS Problem - 12.Jan.2007 1:29:33 AM
asadsq
DNS is installed on the same server where ISA is installed.
As far as definition for "unmodified" is concern is am blank about this coz i am novice in this area & i have no clue about this also i have applied the same technique like i configured the ISA 2K Server. So if it is different method than ISA 2k then plz tell me coz i tried alot options for configuring this problem that i am facing from 2 weeks or so.
Could you please help me in this area?
Regards
Asad
(in reply to spouseele)
RE: DNS Problem - 12.Jan.2007 8:18:04 AM
Hi Asad,
don't you have an internal DNS server? I highly suggest you do!
To summarize the best DNS solution:
1. internal NIC on ISA is first in order.
2. internal NIC on ISA s configured with internal DNS server.
3. internal DNS server is configured with your ISP DNS servers as forwarders.
4. external NIC on ISA do *not* have any DNS configuration.
5. ISA has a rule allowing the DNS protocol from your internal DNS server to the configured forwarders for all users (anonymous).
RE: DNS Problem - 16.Jan.2007 9:38:10 AM
asadsq
Hello Stefaan,
I have tried all options but all in viain nothing worked. I am sending you some print screen images it might help you in my case.
First image:
I tried to insert image but it gives me the following option "
File Either the feature is disabled, or you do not have sufficient permission"
Could you please tell me how can i enable this so that i may send/post images so that it may help you to solve this technical issue?
Regards
Asad
RE: DNS Problem - 16.Jan.2007 3:27:57 PM
Hi Asad,
the easiest way is that you post here a link where we can download the info.
RE: DNS Problem - 16.Jan.2007 6:17:27 PM
ORIGINAL: asadsq
Hello Stefaan,
First image:
Regards
Asad
Hi asadsq,
Send me your JPGs on tarek.majdalani@gmail.com
i will upload the pictures on my Server.
RE: DNS Problem - 17.Jan.2007 3:21:30 AM
These are the pictures you sent me thourgh mail :
i have one comment, why are u still using ISA Server 2004 BETA 2 ????!!!
RE: DNS Problem - 17.Jan.2007 7:12:44 AM
asadsq
Thank you for hosting my images. Reason for using Beta version is that I have downloaded this version & our company is not wanted to invest in ISA Server licesed version thats why. I brought some CD's from market but some of their components were not working properly.
Now from these pictures can you tell me where is problem? In my NIC? in my configuration? in software? or in operating system?
Regards
Asad Siddiqui
RE: DNS Problem - 17.Jan.2007 2:27:44 PM
ORIGINAL: asadsq
Hello Stefaan,
First image:
Regards
Asad
Please answer my questions! Do you have an internal DNS server yes or no?
RE: DNS Problem - 18.Jan.2007 8:17:41 AM
asadsq
Sorry to say what do you mean by internal DNS Server (if DNS configured on this server is said to be internal server then yes i have the internal DNS Server on this computer)
One more thing when i give the command nslookup www.yahoo.com it shows me
Server: itcenter.edu (my domain name)
IP: 192.168.0.1 (my server LAN IP )
& for the next entries it gives me error.
Regards
Asad
RE: DNS Problem - 18.Jan.2007 2:05:51 PM
Hi Asad,
This means on *another* internal server, not the ISA server itself! This is the preferred configuration.
If you only have a DNS server running on ISA itself, make sure that System Policy Rule #8 is enabled and that you have an access rule for DNS from Internal to Local Host.
Post #: 19
RE: DNS Problem - 18.Jan.2007 5:51:58 PM
Also have a look at this article : Internal DNS Forwarding Through ISA Server 2004/2006
Tarek
Post #: 20
