DSL from ISP limitation
All Forums >> [ISA 2006 Firewall] >> General >> DSL from ISP limitation Page: [1]
DSL from ISP limitation - 25.Apr.2007 8:05:47 PM
ashujaku
I have DSL connection from my ISP which has som sort of traffic filtering on their site. As a resust ( i tested various applications) all applications that require direct TCP connection from INTERNAL clients don't connect. If you try the same applications on LOCALHOST (Isa Server) they work like a charm.
So i tested with http://www.isatools.org/tools/winsocktool.msi let's say MSN MESSENGER. Direct TCP connection doesnt work with this configuration (only through HTTP proxy, like all softwares with http support.
Is there a way that i can configure ISA SERVER like a sock2http server for tunneling tcp connections from "Internal' to ISA itelf. . I need to foul around ISP into thinking that ISA does the connection (since I am sure they are doing packet filtering) since every other TCP connection is blocked.
RE: DSL from ISP limitation - 28.Apr.2007 12:44:10 PM
Check with your ISP regarding their service level agreements. If they don't support what you require, see if you can get a new agreement or change ISPs.
(in reply to ashujaku)
