Daily Problem With External NIC Cardproblem
All Forums >> [ISA Server 2004 Firewall] >> SecureNAT Client >> Daily Problem With External NIC Cardproblem Page: [1]
Daily Problem With External NIC Cardproblem - 29.Aug.2007 7:53:12 AM
silent_hack
Please, Could any one help me about that problem, where i should disable and enable again for my EXTERNAL NIC card to let my One BOX ( ISA server 2004, windows 2003 ) as NAT to work properly. that happen almost everyday.
mr.hungrymind
RE: Daily Problem With External NIC Cardproblem - 4.Sep.2007 5:17:24 PM
royh
Are you using pc hardware or server hardware for your ISA machine? What NIC are u using?
Thxs
Roy Haddad,M.Sc
CCNA, MCSE 2003 Messaging & Security,C|EH
(in reply to silent_hack)
RE: Daily Problem With External NIC Cardproblem - 4.Sep.2007 5:35:33 PM
silent_hack
I am using a PC as ISA/Server 2003 as a server
mr.hungrymind
(in reply to royh)
RE: Daily Problem With External NIC Cardproblem - 4.Sep.2007 7:08:39 PM
royh
We had this problem when ISA was installed on a PC. The issue was resolved when we replaced the pc with an entry level Server.
Try updating the driver of your network card and define your networks by mapping the appropriate network adapters to them.
Roy Haddad,M.Sc
RE: Daily Problem With External NIC Cardproblem - 5.Sep.2007 4:42:52 AM
silent_hack
Ok ma, i will try this " about update the NIC driver", then back to u, while i don't understand what u mean with mapping here, mapping if for PC, not for NICs, that what i know.
mr.hungrymind
(in reply to royh)
RE: Daily Problem With External NIC Cardproblem - 5.Sep.2007 6:17:15 PM
royh
when you click your networks node and go to the internal network properties, add the adpater to define your internal network instead of entering a subnet...
HTH
Roy Haddad,M.Sc
RE: Daily Problem With External NIC Cardproblem - 7.Sep.2007 1:28:34 PM
royh
Check also the following link:
http://blogs.isaserver.org/pouseele/2007/08/16/isa-server-and-windows-server-2003-service-pack-2/
Roy
Roy Haddad,M.Sc
