Error Code 11001: Host not found
All Forums >> [ISA Server 2004 Firewall] >> General >> Error Code 11001: Host not found Page: [1]
Error Code 11001: Host not found - 20.Apr.2010 5:56:56 AM
ellisramkumar
Dear All,
We are receive the Following error when we are trying to open www.microsoft.com
but i can open www.hotmail.com.
Error:
Background: This error indicates that the gateway could not find the IP address of the website you are trying to access. This is usually due to a DNS-related error.
Date: 4/11/2010 9:45:11 AM
Server: domain.com
Source: DNS error
We are Using ISA 2004
Could you please help me this issue
RE: Error Code 11001: Host not found - 20.Apr.2010 6:30:16 AM
How is DNS configured within your environment and on the network cards?
(in reply to ellisramkumar)
RE: Error Code 11001: Host not found - 20.Apr.2010 8:04:23 AM
ellisramkumar
Dear Jason Jones,
It was like follows:
for Internal nic - Local DNS Setting  and external nic - ISP DNS Setting, but today only i changed the external DNS setting same like Internal DNS setting as per some expert comment, but no use.
< Message edited by ellisramkumar -- 20.Apr.2010 8:10:20 AM >
RE: Error Code 11001: Host not found - 20.Apr.2010 8:21:32 AM
paulo.oliveira
you should configure your ISA NICs as following: http://blog.msedge.org.uk/2010/04/recommended-network-card-configuration_14.html
Paulo Oliveira.
RE: Error Code 11001: Host not found - 20.Apr.2010 8:45:53 AM
ellisramkumar
Dear paulo.oliveira,
Just Give me like 30mins i will check the setting and i will update you
(in reply to paulo.oliveira)
RE: Error Code 11001: Host not found - 20.Apr.2010 9:02:41 AM
This is probably a better guide for ISA Server 2004 rather than UAG:
http://blog.msfirewall.org.uk/2008/06/isa-servers-recommeded-network-card.html
RE: Error Code 11001: Host not found - 20.Apr.2010 9:05:11 AM
paulo.oliveira
ORIGINAL: Jason Jones
Sorry, wrong link...
Thanks for correct!
Paulo Oliveira.
RE: Error Code 11001: Host not found - 20.Apr.2010 9:24:48 AM
ORIGINAL: paulo.oliveira
Thanks for correct!
Paulo Oliveira.
You now have two to choose from
Do you think we need a TMG one, of does the UAG one suffice for this do you think?
RE: Error Code 11001: Host not found - 20.Apr.2010 9:47:41 AM
paulo.oliveira
The UAG one was on my IEs address bar cache, since it was the last one I viewed.
I think both cover very well for the three products: ISA, TMG and UAG.
By the way, always doing a great work!
Paulo Oliveira.
RE: Error Code 11001: Host not found - 20.Apr.2010 9:55:21 AM
Ok, thanks Paulo
RE: Error Code 11001: Host not found - 20.Apr.2010 10:34:40 AM
ellisramkumar
Dear All,
I tried as per your comments, everything fine and its starts working fine for few mins only after that its giving same error.
Waiting for your comment
RE: Error Code 11001: Host not found - 20.Apr.2010 10:40:53 AM
paulo.oliveira
is ISA your edge firewall?
Does your internal DNS server resolves external domain names properly?
Can you provide details on your HTTP and DNS access rules?
Paulo Oliveira.
RE: Error Code 11001: Host not found - 20.Apr.2010 10:58:49 AM
ellisramkumar
ISA is our Firewall,
i don't know how to check the following: Please let me know how to check this.
DNS Access Rule:
Action: Allow
Protocols: All Outbound Traffic
To: External
User: All User
Content Type: All Content type
No Idea How to check HTTP Rule
RE: Error Code 11001: Host not found - 20.Apr.2010 11:14:23 AM
paulo.oliveira
create two separated access rules, like the following article: Internal DNS Forwarding Through ISA Server 2004/2006
You may not want to include POP3 and SMTP protocols on "Allow Internet" access rule, since these are used for send/receive e-mail from a external e-mail server.
Use nslookup utility to make queries and see if you DNS server is working properly: http://support.microsoft.com/kb/200525
Paulo Oliveira.
RE: Error Code 11001: Host not found - 21.Apr.2010 2:20:33 AM
ellisramkumar
Dear paulo,
Thanks for your Support, i checked all my server DNS setting as per the article, in the DNS setting
Forwarders tab there are some other IPs mention and i change it to our current ISP's DNS IPs. and i create the Rule for ISA server as per your article, then the result is same.
RE: Error Code 11001: Host not found - 21.Apr.2010 2:43:17 PM
paulo.oliveira
I can't think anything else about it. The main configuration are the ones I've told you to do.
It's hard to tell if there's something besides it without knowing your environment.
Hope someone come with other ideas.
Paulo Oliveira.
RE: Error Code 11001: Host not found - 14.Jun.2010 9:20:40 AM
sowmika
Hi,Error is possible one, for this contact your service provider , I am not face these kind of problem ,I am using this http://www.thewebpole.com/ site's hosting service at very cheap rate ,here provide more reliable and excellent support for my website ,you may also try this site for more details.All the best.
RE: Error Code 11001: Host not found - 20.Feb.2012 4:26:57 AM
venkat
This is nice one..................
(in reply to sowmika)
