Error Code 502 Not enough storage availavle
All Forums >> [ISA 2006 Firewall] >> General >> Error Code 502 Not enough storage availavle Page: [1]
Error Code 502 Not enough storage availavle - 21.May2008 1:40:47 AM
don.nit1
Error Code 502 : Not enough storage is available to process this command.
I am getting above error after 2 0r 3 days then i can not browse any sites for this I will have to restart the server everytime whenever i got the error. I kindly request you to please provide me the solution.
I have search on google also and make some changes in registry but no use still getting the same error.
Thanks & Regards.
Don Nit
System Administrator
RE: Error Code 502 Not enough storage availavle - 29.May2008 12:58:43 AM
don.nit1
Are the gurus here have been stumped by my error that there is not even a single reply.
Is this error first time encountered by me only ????
Please anybody out there knows the solution as this error makes me reboot my ISA 2006 Server every alternate day
Any pointers suggestion most welcome.
Thanks & Regards
Don Nit
(in reply to don.nit1)
RE: Error Code 502 Not enough storage availavle - 29.May2008 3:42:15 AM
could be  related to shortage in memory.
How much memory you have ?
in task manager you could quickly check if any process is eating your ram
RE: Error Code 502 Not enough storage availavle - 4.Jun.2008 2:46:56 AM
don.nit1
In my office there is a 100 user as per your advice I have upgade the Ram from 1 gb to 2 gb.
Is it sufficient RAM for 100 user please let us know.
Following is the service which is eating RA>
wspsrv.exe
Thanks & Regards
Don Nit
(in reply to elmajdal)
RE: Error Code 502 Not enough storage availavle - 4.Jun.2008 3:54:01 AM
What updates for ISA have you installed?
Check you have the ISA 2006 Supportability Update and it may also be worth installing the latest April 2008 hotfix package.
http://support.microsoft.com/kb/939455
http://support.microsoft.com/kb/951510/en-us
2GB should be more than enough for 100 users...
Silversands Ltd
http://www.silversands.co.uk
RE: Error Code 502 Not enough storage availavle - 5.Jun.2008 9:11:11 AM
don.nit1
Hi Sir,
As per your suggetion I have installed the april 2008  hot fix.
Now i am watchin still the problem is there or not.
Thanks & Regards
Don Nit
RE: Error Code 502 Not enough storage availavle - 6.Jun.2008 5:12:01 AM
don.nit1
As per your suggestion, I have upgrade the RAM and installed all latest April Hotfix what you have suggested but ,still I  am facing the same problem.
Is anything else I need to be done ?.
Please let me know.
Thanks & Regards
Don Nit
RE: Error Code 502 Not enough storage availavle - 6.Jun.2008 6:40:35 AM
How much free space do have on all your drives?
How is your page file (virtual memory) configured?
When you get the errors, can you look in task manager and look at which process is using the most amount of RAM and how much is being used?
Have you tried deleting your cache file?
Are you using MSDE logging?
Have you got any URL filtering products installed?
Are you running Windows SP2?
Have you run the ISA Server Best Practice Analyser to look for common problems?
Just a few ideas...
< Message edited by Jason Jones -- 6.Jun.2008 6:43:20 AM >
Silversands Ltd
RE: Error Code 502 Not enough storage availavle - 10.Jun.2008 1:23:22 AM
don.nit1
Dear Sir,
I Have
17 Gb Free Space on C
19 Gb Free Space on D
Recommended Page file 3058kb
Currently 5000 KB on c:
While getting the error the wspsrv.exe service is taking most amount of RAM
It is  169122 KB.
I never tried to delete cache file.
Yes i am using MSDE logging.
No
I am using Windows SP2
I have install Best Practice Analyser for ISA 2006.
But Still I am facing the sam problem ?
Please Suggest me anything else I have to do?
Thanks & Regards
Don Nit
RE: Error Code 502 Not enough storage availavle - 10.Jun.2008 4:28:51 AM
How big is your cache drive?
It may be worth clearing your cache drive as shown here:
http://forums.isaserver.org/m_2002014168/mpage_1/key_/tm.htm#2002015070
Le us know how it goes...
Silversands Ltd
RE: Error Code 502 Not enough storage availavle - 11.Jun.2008 4:20:30 AM
don.nit1
Hi ,
As per your suggetion I have deleted the cache file
Let see what happened ?
Thanks & Regards
Don Nit
RE: Error Code 502 Not enough storage availavle - 11.Jun.2008 4:33:18 AM
Ok, keep us posted - anyone else got any bright ideas???
Silversands Ltd
RE: Error Code 502 Not enough storage availavle - 12.Jun.2008 8:59:03 AM
don.nit1
Hi Sir,
Still I am facing thesame problem.
Today I have restarted twice .
But this time I got the new error twice.
Event Id :14167  Microsoft ISA Server Web Proxy.
What should I  have to do on this new error ?
Please let me know.
Thanks & Regards
Don Nit
RE: Error Code 502 Not enough storage availavle - 16.Jun.2008 6:08:36 AM
don.nit1
somebody read my error and provide me solution
If it is possible
Thanks & Regards
Don Nit
RE: Error Code 502 Not enough storage availavle - 14.Aug.2008 4:13:51 PM
minerat
I've run into the same error twice now since early July.  I'm running 2006 SP1, supportability update, etc.
My server has 4GB of ram, a 20GB cache and had a 6GB page file (split to two 4GB files now).  Plenty of free space on both drives.
When I opened ISA Management and went to cache, it told me the size of the drive/size of the cache was unavailable.  I refreshed and it displayed correctly - browsing worked for a short while, then right back to 502.
I created the IRPStackSize reg key and set it at 18 and rebooted.  We'll see how that holds up - once the issue is resolved it takes a while to reappear.  Previously I disabled caching, deleted the cache file and reenabled it.  The service restart could have been the fix, and not this action.
I'm using MSDE logging (was using 1.7GB before reboot).
I have two web filters installed - GFI webmon w/norman+bitdefender and ClearTunnel.  I've used webmon for a while - with 2004 standard and did not have this problem.
I only have 85 web browsing users (this is just a firewall/proxy for web browsing) and it's sitting on a 6mbit DSL connection.
RE: Error Code 502 Not enough storage availavle - 25.Aug.2008 1:51:39 PM
minerat
The error is back (again).
(in reply to minerat)
RE: Error Code 502 Not enough storage availavle - 25.Aug.2008 4:02:05 PM
pwindell
Well folks,
I haven't had this trouble on an ISA, but have had on other machines.
Check the Value of this registry entry.  Try a value somewhere between 6 and 11.  Just remember what it was at to start with so if this doesn't work you can put it back where it was.
HKEY_LOCAL_MACHINE SYSTEM\CurrentControlSet\Services\LanmanServer\Parameters
Value Name: IRPStackSize
Data Type: DWORD
Default: 0x4
Maximum: 0xC
Phillip Windell
www.wandtv.com
