Everquest 1 and ISA 2000
All Forums >> [ISA Server 2000 Misc.] >> Gaming >> Everquest 1 and ISA 2000 Page: [1]
Everquest 1 and ISA 2000 - 7.Dec.2004 9:47:00 AM
stevecocks
Hi all
I see you guys have worked out how to setup EQ2, was wondering if anybody has a working EQ1 setup.
I tried last night and setup as per some instructions I found on the web:
code:
EverQuest Patch Server
Primary Connection (1)
7000
TCP
Outbound
EverQuest Login/Chat Server
Primary Connection (2)
5999
UDP
Send Receive
Secondary Connection (2)
5998
UDP
Send Receive
EverQuest World Servers
Primary Connection (3)
9000
UDP
Send Receive
Secondary Connection (3)
1025-65535
UDP
Send Receive
Special Notes:
Firewall Proxy Client Required: Yes
You must make three separate protocol definitions
for this to work properly.
I'm not too sure about the range of ports for the
secondary (3). This should work, however I would
to be more exact on what ports are used here so
we don't have to have such a large port range.
If anyone knows exactly what ports to use here
please let me know.
So I followed these instructions and was able to
patch EQ. However I wasn't able to login.
Going to the official Everquest site has no entry listed for ISA server specific configurations, just this information.
code:
Firewall/Proxy Information
We do not formally support the use of firewalls
or proxies, including home cable modem/DSL NAT
routers and other Internet Connection Sharing
devices or software. However, the following
information might be helpful if you need to
troubleshoot a connection that utilizes one of
those technologies:
Patch Application:
A TCP connection is initiated from the player's
PC (using ports numbered >1023) to
patch.everquest.com, port 7000. There are
multiple IP addresses for the patch.everquest.com
clusters, and they may change as the network
demands, so check often using a DNS lookup tool
if you provide a specific firewall rule for
patching.
EverQuest client:
UDP datagrams are sent to/from the player's PC
(using ports numbered >1023) from/to the
EverQuest servers (using ports numbered >1023).
Additionally, ICMP Unreachables (ICMP type 3) are
sent to/from the player's PC from/to the
EverQuest servers.
The EverQuest server IP addresses are on the
subnets:
64.37.148.* , 64.37.156.* , 195.33.133.*,
199.108.3.* 199.108.4*, 199.108.5*, 199.108.9*,
199.108.15*
Please note that EverQuest opens a random UDP
data port from the player's PC every time
EverQuest is run. Thus, the need to have all
ports >1023 available.
Anybody have any ideas? I suspect that I they have added / changed the ports for login or chat and actually dont mention any of this in their official details on proxy / firewall settings. Kinda hoping one of you guys might have cracked it.
/Steve
[ December 07, 2004, 09:51 AM: Message edited by: Steve ]
RE: Everquest 1 and ISA 2000 - 21.Dec.2004 9:13:00 PM
munchi
I had same problem for some time but today i found out if u add a protocol definition with UDP port 15900 Send/recieve to above config, it will work.
GL
/munchi
(in reply to stevecocks)
