FTP and SNat clients
FTP and SNat clients - 9.Jan.2002 12:10:00 AM
MagickMan
I cannot download files from a full url path using Snat clients Ie.. ftp://host/filename It comes back with a DNS error. IF I enter just the host url I connect and get a listing, but again if dbl click the file, no go. (Right clk, copy to folder does work) If I set the client as a Web proxy client everything works as it should. It seems to be acting as though the App filter is not enabled but it is. Any suggestions? MM
RE: FTP and SNat clients - 14.Jan.2002 5:53:00 PM
MagickMan
Any suggestions??? Anyone
RE: FTP and SNat clients - 15.Jan.2002 5:25:00 AM
Have you tried turning off the "Enable folder view for FTP sites" checkbox in teh advanced IE properties? Also try setting IE to passive mode (also in advanced properties). ------------------ Regards, Jeremy email: jeremy@cableserver.co.uk www: www.cableserver.co.uk MSN Messenger: jeremybcooke@hotmail.com Two books I highly recommend: (Click an image to see the book at amazon)
RE: FTP and SNat clients - 18.Jan.2002 11:15:00 PM
MagickMan
I have tried changing the IE options. This doesn't seem to make any difference.
RE: FTP and SNat clients - 14.Feb.2002 11:52:00 PM
Spike
Magick Man, did you ever get this to work? I am having similar problems. I can get connected to an ftp site, but then get errors. Below is what the tech guy on the site I am trying to get to shows and tells me.
tflr2000# ftp 209.11.160.21 Trying 209.11.160.21.21... Connected to 209.11.160.21. 421 Service not available ftp> ftp update.8e6.net Trying 209.11.160.24.21... Connected to update.8e6.net. 421 Service not available ftp> Error 421 is caused by something called tcp wrappers in the router etc., where there are two files, host.deny and host.allow typically. You will have to modify this to allow R2000 to be able to ftp out to certain locations.
RE: FTP and SNat clients - 15.Mar.2002 11:54:00 PM
tebrainard@rochester
I have the same issue, tried various versions of IE, teaked polisies. A packet trace show that the ftp request is issuing a "dir" on the \\ftp:ftp.sit.file.txt command, rather than a "get" file command
I can navigate to the file name in the ftp site and copy, but FTP is easier.
RE: FTP and SNat clients - 18.Mar.2002 7:15:00 PM
ToddC@kpcom.com
Similar issue here -- Secure NAT client. I'm able to use FTP client software just fine with Passive Mode OFF (no passive). But trying to access/download files via Internet Explorer (FTP via HTTP) is dying with a DNS, no page error.
Any thoughts on what settings to look at?
ToddC
RE: FTP and SNat clients - 18.Mar.2002 8:14:00 PM
Hey guys,
I've tested this a million times and FTP always works with SecureNAT clients as long as you have:
1. No access controls requiring the SecureNAT client to provide credentials (because they can't)
2. FTP access filter enabled
3. Do not configure the FTP software to use the proxy
HTH, Tom
RE: FTP and SNat clients - 19.Mar.2002 10:56:00 PM
thanks, finally got it.
RE: FTP and SNat clients - 27.Mar.2002 8:26:00 PM
robbie0ne
quote: Originally posted by Spike: Magick Man, did you ever get this to work? I am having similar problems. I can get connected to an ftp site, but then get errors. Below is what the tech guy on the site I am trying to get to shows and tells me.
Hello, Did you ever figure this out. I have the exact problem.
Thanks.
RE: FTP and SNat clients - 28.Mar.2002 6:01:00 PM
Hi Robbie,
No figuring! Just do what I said above, and make sure that you don't have access policies that are blocking anonymous requests.
HTH, Tom
RE: FTP and SNat clients - 12.Jun.2002 4:45:00 AM
WPinegar
I have this the exact same problem as describled in this thread. I've discovered however that if I set the proxy server settings in IE that FTP downloads work flawlessly...
RE: FTP and SNat clients - 12.Jun.2002 10:12:00 AM
iliko
Hi everybody. How to enable ftp access filter so that my SNAT clients can access all the ftp servers?
RE: FTP and SNat clients - 12.Jun.2002 8:01:00 PM
Hi iliko,
it's under Extensions -> Application Filters .
HTH, Stefaan
RE: FTP and SNat clients - 1.Jul.2002 7:50:00 PM
shariqs
Try installing the ISA server service pack 1. I was experiencing a similar problem and it fixed my issue.
Hope this helps.
RE: FTP and SNat clients - 2.Jul.2002 3:41:00 AM
Hey guys,
Also make sure that you do NOT configure the FTP client application to use the ISA Server as a firewall. The access should be completely transparent.
HTH, Tom
RE: FTP and SNat clients - 4.Jul.2002 5:21:00 PM
Hey guys,
Regarding the FTP issues, check my FAQ on this. You can search the Site using the "Site Search" or go to www.isaserver.org/shinder. There does seem to be a bad problem with SecureNAT and FTP if you're using PASV.
RE: FTP and SNat clients - 5.Jul.2002 6:49:00 PM
MagickMan
Thanks Tom for getting to the bottom of this. Now the big wait for the fix.
RE: FTP and SNat clients - 30.Aug.2002 6:59:00 AM
ToddC@kpcom.com
Tom,
Maybe there is a miss-understanding in this thread?
I and others seem not to have a problem with FTP client software, eg., CuteFTP, FTP Explorer. Rather, when Internet Explorer tries to download a file from a web site that links to an FTP site (in the browser address field, example: ftp://ftp.prserv.net/pub/client/win32/ncsetup.exe) then there is this problem of not connecting and getting the DNS error, no page, etc.
I've tried all kinds of settings in IE for this. Still to no avail. Not sure what to do. Is this possibly related to the FTP problem you alluded to re SecureNAT, FTP and PASV mode?
ToddC
