FWX_E_TCP_NOT_SYN_PACKET_DROPPED
FWX_E_TCP_NOT_SYN_PACKET_DROPPED - 30.Dec.2005 8:07:30 AM
wbplomp
Hi, When I filter my logging on Denied Conenctions I see a lot of result codes with FWX_E_TCP_NOT_SYN_PACKET_DROPPED. Is this normal or does anyone know what to do about it? I think is may have something to do with unicast traffic on a Cisco Catalyst switch, am I wrong? Boudewijn
RE: FWX_E_TCP_NOT_SYN_PACKET_DROPPED - 25.Jan.2006 8:19:31 PM
wbplomp
Hi Tom, I still don't have a solution to this problem. One of my colleges at another company has the same issue. I was at the Microsoft office today in The Nederlands, but unforunally I wasn't able to talk to one of the support specialists. Do you have any suggestions regarding FWX_E_TCP_NOT_SYN_PACKET_DROPPED ? Greetings, Boudewijn
RE: FWX_E_TCP_NOT_SYN_PACKET_DROPPED - 26.Jan.2006 10:34:37 PM
wbplomp
Hi, Thanks for the link, but nothing is related to this error. Boudewijn
RE: FWX_E_TCP_NOT_SYN_PACKET_DROPPED - 28.Jan.2006 2:12:35 PM
Hi Boudewijn, not directly but the same principles regarding impatient applications and delayed responses are valid here too. Take a netmon trace and compare it with the ISA loggging if you want to find out what is the exact cause of those denied connections due to FWX_E_TCP_NOT_SYN_PACKET_DROPPED. HTH, Stefaan
RE: FWX_E_TCP_NOT_SYN_PACKET_DROPPED - 30.Jan.2006 7:28:54 PM
wbplomp
Hi Stefaan, I think I have found the problem. I think it has something to do with ICMP Redirect. ISA Server is not compatible with ICMP Redirect. We have a central switch that is also a router. The router IP Address is used as a default gateway wich forwards all traffic to ISA Server on the same subnet. But all servers seem to learn that path from the central switch/router by ICMP Redirect. ISA Server does not like that at all. But even that is an issue, because inbound traffic is passed directly to the servers by ISA Server, without ICMP enabled on the server, the server repsond not directly. I hope you can follow it. See this microsoft Knowledge Base article related to this issue. (my only concern is that it only discribes ISA Server 2004 Standard Edition. ISA Server 2004 does not support traffic redirection http://support.microsoft.com/default.aspx/kb/888042 Greetings, Boudewijn
RE: FWX_E_TCP_NOT_SYN_PACKET_DROPPED - 30.Jan.2006 8:06:14 PM
wbplomp
Hi Stefaan, I've read these articles. But I cannot find al solution related to this issue. Or am I wrong? HTH, Boudewijn
RE: FWX_E_TCP_NOT_SYN_PACKET_DROPPED - 30.Jan.2006 9:02:11 PM
wbplomp
Hi Stefaan, Exactly, that should give you the best result. In my case we have a Cisco 3500 layer 3 switch. On this switch serveral, for about 8 gateways and 4 servers are directly connected in the same subnet. The IP Address of the switch is the default gateway for every device, wich sends every route the ISA Servers with NLB as it's default gateway. But server seem to learn a shorter path directly to the ISA Servers. The only thing is, it should be possible. I did some testing with static routers, but it does not seem to work. I only have the problem with NLB enabled. Do you have spcecial configurations on your layer 3 swtich? Do you use Cisco? If you do, do you have spanning-tree portfast enabled on some ports? HTH, Boudewijn
RE: FWX_E_TCP_NOT_SYN_PACKET_DROPPED - 12.Feb.2006 8:00:53 PM
adenhaan
Boudewijn, The following suggests incompatibility between W3K NLB and Layer-3 Switches : http://download.microsoft.com/download/3/2/3/32386822-8fc5-4cf1-b81d-4ee136cca2c5/NLB_Troubleshooting_Guide.htm#_4.3.5_Cause:_Switch_is_operating_in I experienced the TCP_NOT_SYN_PACKET_DROPPED myself, and for me the reason was indeed another router on the network which caused the routes from host A to host B to be different routes from host B to Host A. In other words, Host A was able to directly access host B (Sending a SYN without going through default gateway / ISA), however host B could only reach host A through ISA (causing the reply to the SYN to be rejected by ISA, because ISA never saw the SYN). Note that in this scenareo, hosts can Ping eachother, however can not establish tcp connections. in either case the doc might give you additional hints, it's worth putting in your favourites. G'luck, Andre.
< Message edited by adenhaan -- 12.Feb.2006 8:02:25 PM >
RE: FWX_E_TCP_NOT_SYN_PACKET_DROPPED - 28.Nov.2007 8:54:02 AM
geeked4Scuba
We were getting this same error last night. We are using ISA 2006 and the user's PC is not part of our domain and was running IE7. The user does have account on the domain. We unchecked the "Enable Intergrated Windows Authenication" in IE 7. It can be found in IE7, Tools, Internet Options, Advacned, (scoll down near buttom, just above Phishing filter). Now he gets prompted to Authenicate before the ISA server allows the traffic. It didn't seem like the error and fix had anything to do with each other, but I had both PCs (my and the users) sitting side by side. When I unchecked the check box, everything started working as planned and no errors in the ISA monitoring of his IP address.
Your Dog can not eat your homework if you don't do it ahead of time.
